Metal Blocks On Top Of Exhaust Pipe
Old 09-11-2007, 11:07 AM
ZRXKUMA's Avatar
ZRXKUMA
ZRXKUMA is offline
Why are there 2 metal blocks attached to the top of the exhaust pipe of my 2007 5.4 F150? They aren't associated with any mounting brackets and are about 3/4 inch high and about 2 inches long mounted about an inch apart back towards the bed of the truck before the muffler. If it were a drive shaft it would look like balance weights were attached. Are they some sort of anode to prevent rust?
Old 09-11-2007, 12:30 PM
Corey872's Avatar
Corey872
Corey872 is offline
I haven't seen them, but it sounds like it may be a NVH (Noise, Vibration and Harmonics) damper. Ford might have found out that the exhaust pipe likes to vibrate at a certain speed (probably right at some common speed, like freeway cruising) so they tacked a couple of slugs of metal onto the pipe to change the vibration characteristics.
Old 09-11-2007, 01:44 PM
mrpositraction's Avatar
mrpositraction
mrpositraction is offline
Sounds plausible. By doing this you would change the natural frequency there for moving the rattling up or down from the point of interest.
TallPaul
Exhaust Systems
11-08-2012 07:48 PM
pin8246
08-05-2012 10:24 PM
chi6488
6.4L Power Stroke Diesel
01-30-2012 07:34 AM
LaRell
08-05-2007 04:29 PM
SBV45
06-29-2004 06:10 AM
Quick Reply: Metal Blocks On Top Of Exhaust Pipe
