Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 12-04-2007, 04:16 PM
panel 56 panel 56 is offline
panel 56 is starting off with a positive reputation.
Thanks Bobbytnm,
All that information will be very helpful. I also have a '38 Nash business couple that I work on from time to time. I am in the process of saling it if you know of anyone looking for one. It is in really good shape for its age.
  #92 (permalink)
Old 01-09-2008, 01:58 PM
sid318 sid318 is offline
sid318 is starting off with a positive reputation.
Hi all , i use blue tac to hold nuts in my spanner when i can't reach them myself, ie manifold bolts & alike.
  #93 (permalink)
Old 01-09-2008, 05:33 PM
What Is Blue Tac?
  #94 (permalink)
Old 01-09-2008, 06:11 PM
AXracer's Avatar
AXracer AXracer is online now
AXracer has a good reputation on FTE. AXracer has a good reputation on FTE.
Here we call it "Fun Tac", it a a removable and reusable adhesive putty sold in the stationary and school supply departments. It comes in a small blue or white block about the size of an eraser and is promoted for hanging posters and pictures on walls without damage. I use it a lot to temporarily stick things together. I even stick gemstones into place on a ring with it so customers can get a feel for what it might look like mounted. The more you warm it by squeezing and stretching it in your fingers the softer and stickier it gets.
__________________
Passionate about autocross racing!
2003 GSL, 2005 HSL National Champion
1956 F100 Panel support/tow vehicle
2007 Solstice GXP racer, the "KRAZED KANARY"
2002 Celica GT 2003 GSL National Champion retired to daily driving duties
  #95 (permalink)
Old 01-09-2008, 07:56 PM
jniolon's Avatar
jniolon jniolon is offline
prone to instability
jniolon has a good reputation on FTE. jniolon has a good reputation on FTE. jniolon has a good reputation on FTE.
dry cut metal saw
I don't know if this qualifies as a "tip or trick" or more of a tool recommendations.
Back a few months ago Joe Gaddy told me about a dry cut metal saw blade that could replace an abrasive blade in a chop saw. They are made by Bullet Industries. The 14" model (chop saw size) is about 50 bucks. I ordered and finally got to install tonight.
clamped in a piece of 2x2x¼" angle iron and dropped the blade down.. It almost fell thru the metal !!! If you've used a chop saw you know about pressure on the blade and the mess it makes. Only the lightest pressure is needed...just let the blade do the work. It's like a hot knife thru soft butter.. The output was very fine chips of metal that pretty much stay close to where you're cutting and not floating around in the air and up your nose like the abrasive dust.
I can't say anything about longevity yet, but for speed of cut and ease of cut this is the best I've found... check them out below
http://www.bulletindustries.com/cata...roducts_id/784
later
john
__________________
Any day above ground... is a GOOD day !!!
  #96 (permalink)
Old 01-12-2008, 01:49 PM
cmoritz cmoritz is offline
cmoritz is starting off with a positive reputation.
Can"t keep that nut/bolt in the socket?..Lay a small piece of paper over socket opening,then stuff in the nut..,still too loose? use thicker paper.
  #97 (permalink)
Old 01-12-2008, 02:01 PM
Heating a stuborn nut/bolt with a torch? Try spraying stream of cold water from an adjustable spray bottle..shock therapy..you are wearing your safety glasses and gloves arn"t you??..this is going to be a good thread ..thank"s.
  #98 (permalink)
Old 01-14-2008, 09:32 AM
59dumper 59dumper is offline
59dumper is starting off with a positive reputation.
hate taking the time to clean up all those rusted nuts, bolts, washers, small parts... Buy one of those cheapo rock tumblers throw in a couple of handfuls of nuts bolts etc... fill most of the way with abrasive (I used garnett for the first round) worked pretty good but I think black diamond might do better. This will take a few days in the tumbler so its not a quick thing but if you're in no hurry set it up and forget it for a day or two and you've got shiny new hardware that goes together like new.
  #99 (permalink)
Old 01-15-2008, 08:31 PM
Here"s a couple of easy one"s; Old bolt too tight to loosen ? tighten it a little first ,Can"t get a nut started on a bolt/stud ?Try spinning it on ..backwards..slowly until you feel it drop ,,now try threading it on ..sorry , those were too easy not to pass along.
  #100 (permalink)
Old 01-24-2008, 02:41 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack is gaining momentum as a positive member of FTE. Randy Jack is gaining momentum as a positive member of FTE.
Using Clecoes To Align Body Panels:
Having some time on my hands, I read this thread from the beginning. Good stuff, folks! However, I couldn't believe nobody talked about clecoes.
We all know what a pain it is to align body and door panels for a good fit and how tough it is to repeat that fit later (like after finish paint). Here's the slickest way I have seen and used:
Drill (2) 1/8" diameter holes thru mating seams of the parts (like inner/outer fenders/air dams, etc). Then install some 1/8" clecoes in these holes. When you reinstall the parts, just insert the clecoes into their holes and the part alignment repeats exactly. I have had my entire 56 front clip on the truck using clecoes only. Works great.
A good source for clecoes is Eastwood. Believe it or not, they are less expensive than McMaster Carr. Eastwood's part numbers: 19075, (30) "blind holders", $21.99; 19074A, compression pliers, $12.99. The clecoes (holders) are pretty useless without the pliers.
I did a variation on the cleco theme with re-hanging my doors. If you aren't familiar with clecoes, they are used and pictured here: http://www.ford-trucks.com/user_gall...&albumid=27817
Rock on!
__________________
Randy Jack
56 F100 Street Rod Daily Driver
Growing OLD is mandatory. Growing UP is optional.
Inside every old guy is a younger guy wondering what the heck happened.
  #101 (permalink)
Old 01-24-2008, 10:59 PM
fatfenders56's Avatar
fatfenders56 fatfenders56 is offline
fatfenders56 is starting off with a positive reputation.
what a great thread, I don't get a whole lot of internet time lately but this was a good use of it, thanks guys
__________________
if you can think of it, I can make it
  #102 (permalink)
Old 02-13-2008, 12:51 PM
homade's Avatar
homade homade is offline
homade is starting off with a positive reputation.
Panty hose to keep it cool-------fan belt broke, overheating,ofcourse this was a long time ago and the girl with me had on panty hose,so i had to borrow them, just streach around pulley's real tight ,tie hard knot and remove excess, instant fan belt. to remove excess use knife or chew it off,prefence is everything.
  #103 (permalink)
Old 02-13-2008, 02:01 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has a good reputation on FTE. bobj49f2 has a good reputation on FTE.
Quote:
I wish I had know this maneuver when I was dating my wife, oh yeah, it would have come in handy if my truck would have over heated too.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup/48 F-1 panel truck
48/51 F-4 flatbed (2 in 1)/49 8N tractor
www.fatfenderedtrucks.com
  #104 (permalink)
Old 02-14-2008, 03:10 PM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has a good reputation on FTE. bobbytnm has a good reputation on FTE.
I had success with it one time and completely failed with it another time.
Of course, the time that didn't work was because I had a serpentine belt system....lol.
I had lost an idler pulley on a cross country trip and threw the belt. I knew I wouldn't be able to spin up every accessory but I was trying to get a minimum of water pump and alternator (yup it was night time so I need the extra juice) In the end, I got a hotel room and waited until the parts store opened the next day.
...so it goes....
There are some great tips in this thread
Bobby
__________________
...Someday our foes may win...
...but NOT today!!
1949 F1, 500ci Caddy
1959 Dodge D100
1965 Falcon
1994 Harley Road King
  #105 (permalink)
Old 02-14-2008, 05:30 PM
rdemilt's Avatar
rdemilt rdemilt is offline
rdemilt is starting off with a positive reputation.
He did say chew them off didnt he you da Man !!!
Rick
Tags
ford , tricks , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
