1989 f250 xlt lariat shifting funky
should I do this cold, hot or does it matter? Either way if the diaphragm is leaking it’ll leak regardless correct
To get a good fluid reading? It needs to be warmed up. But start it up, and check it cold, to make sure that it's not low cold. A C6 will take alot of abuse, including low fluid, before it starts breaking or wearing things out, but it's still not a good idea. And yes, if the diaphragm is leaking, it's going to do it hot, or cold.
This will sounds strange but it might be your lights... I read before about turn signal lights causing the tranny to down shift due to mismatched bulbs sending signals to the computer... ya strange but I personally know this to be true, just not sure it pertains to this year truck... the one I helped with was a mid 90s. Did you recently change a directional bulb to LED?
keeblr
02-27-2018 08:25 PM
terramir
07-03-2008 11:13 AM
90F250351
08-03-2007 08:44 AM
