Increases throttle response gets fuel in quicker by opening injector sooner. I think Beans or BTS will exchange a modded one for $100. You can put a sd idm in and boost injector voltage to 120 stock 97olderis 100. Modded are 140volts.
I think I will still give it a try, IF I can find a SD at the Junk Yard.. Ill look for that spider for you Neal while I am there. If I cant find one, Neal, did you just send yours in and how long does it take?
Well I live near there so I drove there and changed it in the lot. ~ 5 minutes. I believe will take them a few days possibly. He may have one there already done. He will send you one and charge you a core and then you can send yours back if you want. Call them to see, I usually speak with Dusty.
Okay, I found one at the local Pick and Pull out of a 00 superduty. 15 bucks out the door. Does the same mod wrok if I try to make it a 140 one? I should problaby just leave it alone but where"s the fun in that?
