Why could timing be this far advanced?
Old 11-23-2002, 11:40 AM
big block power's Avatar
big block power
big block power is offline
I checked the timing on my mix match 390 and it's set right off
the marks past 30degrees btc. My other 390 could't stand more than
14 degrees. Whats up with this? Could a different cam call
for different timing? I set the timing to 8-10 degrees(fat piece of
chalk) and noticed a little low end loss.
This engine confuses me
Old 11-23-2002, 11:57 AM
Ratsmoker's Avatar
Ratsmoker
Ratsmoker is offline
Set your initial to about 12 degrees. Make sure your timing is advancing when engine rpm increases. It is possible that your balancer has slipped a little causing a false indication but I doubt it.
Old 11-23-2002, 01:07 PM
big block power
Not a problem was jes kinda curoius.
Fe power
Old 11-23-2002, 02:03 PM
gtex's Avatar
gtex
gtex is offline
I have high duration cam and it like to be advanced well beyond 10 BTDC at idle. It will idle best with the inital timing even above 20, but then the advance at higher RPMs results in pinging.
In short, I think some cams will require higher initial timing. It is even mentioned in my Edelbrock carb tuning guide.
Old 11-23-2002, 02:14 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
I am having the same problem.
I used a dwell meter to set my points to 26 (gapping them was way off) and my timing to 6. It advances to almost 40 degrees at 2000 rpms in the driveway and it dogs down at highway speed and I have lost top end speed set to factory specs. I still get a shaking at crusing speed (60 mph). Mine is a mixmatched mess too.
I am going to try 12 degrees as suggested.
Old 11-24-2002, 02:25 PM
big block power
This thing only lacks a wee in the low end until I change the
timing back to where it was, the truck will pass a
3 car line up on the highway pretty quick, I've had
cars ruin my passing schemes before cause they just don't
have the guts to make it all the way.
Fe power
Old 11-24-2002, 04:03 PM
proeliator's Avatar
proeliator
proeliator is offline
that is one heck of allot for initial timing, regardless of your cam. While its true cam profiles can benefit from different advances, Rats advice of 12 initial is a good place to start. Typically, even the radical FEs don't have more than @18 btdc to begin with, and 42 total in. I've found that mine is happiest at 14btdc and 38 total, in by 2700 rpm. It can handle 18 initial with 42 total but then I start to worry about detonation. Timing tape is a cheap and valuable tool in dialing in your timing, have fun.
Old 11-24-2002, 05:39 PM
mlf72f250's Avatar
mlf72f250
mlf72f250 is offline
[updated:LAST EDITED ON 24-Nov-02 AT 06:42 PM (EST)]Check to make sure your centrifugal advance is working.
When I first got my truck it needed lot of advance, too. First I checked to make sure the timing marks were right. There is a thread out there where the folks here helped me quite a bit. The marks were spot-on. As it turned out, the centrifugal advance was frozen solid. This was diagnosed by disconnecting the vacuum advance, reving the engine, and reading the timing (it didn't budge). It needed a lot of initial to run right. Once I pulled the distributor and got the advance mechanism loosened up, it runs pretty well with 10-15deg initial.
--Matt
1972 F250 Custom Sport Camper Special 4x2 360 2v C6 3.73
Some day hope to shorten to a 104" wheelbase as part of a Broncification project
My FTE Website -- http://www.clubfte.com/users/mlf72f250/index.html
My Galleries -- https://www.ford-trucks.com/user_gallery/displaygallery.php?userid=1108
Old 11-24-2002, 11:42 PM
390fe's Avatar
390fe
390fe is offline
