Computer Trivia
Received 1,353 Likes
on
on
I guess that's close enough. I added a second video card but it is linked to the first video card in a SLI configuration.
Wreck you should see my computer as it is a "hot rod" of sorts (just can't find the camera). I've clocked my 2.4 ghz CPU to 2.8 ghz. I could do 3 ghz but I need a better cooler and I have to play with the voltage which I don't like to do. I can make more than trucks go fast!
Scalable Link Interface (SLI) is a brand name for a multi-GPU solution developed by NVIDIA for linking two (or more) video cards together to produce a single output. SLI is an application of parallel processing for computer graphics, meant to increase the processing power available for graphics. With SLI, it is possible to theoretically double the power of your graphics solution just by adding a second video card with an identical GPU. The basic idea of SLI is to allow two (or more) graphics processing units (or GPUs) to share the work load when rendering a 3D scene. Ideally, two identical graphics cards are installed in a motherboard that contains two PCI-Express x16 slots, set up in a master-slave configuration. Both cards are given the same part of the game (scene) to render, but effectively half of the work load is sent to the slave card through a connector dubbed the SLI Bridge. For example, in some cases the slave card will work on the bottom half of the screen. The slave then sends its rendered output to the master card, where it is incorporated into the master card's own image (in the frame buffer) and sent to the screen.
on
Originally Posted by wreckhaul
...and I still don't know what a rep point is LOL
