GPR Cutoff Switch In
Yesterday I installed my GPR cutoff switch. I switched the hot wire to the relay primary side. Mounted the switch at the top left of the little cubby on the right side of the steering wheel near the bottom of the dash. Works great. I think this mod is a good idea for extending GP life. GPs are not needed in the summer at all.
Westtntrucker, since you asked, here are a couple pics:
Here's the relay. I put the switch in line with the small red wire w/ the light green looking stripe. I think the stripe is actually white - just looks pale green in the pic. I ran the wire through a hole in the firewall just above the gas pedal.
http://www.supermotors.net/vehicles/...y/media/559025
Here's the switch in the dash. I didn't bother to hook up the light. These types of switches look a whole lot cleaner than metal toggles.
http://www.supermotors.net/vehicles/...y/media/559026
