??? are there only two wheels designed for a stock turbo???
Just a thought, I know about the stock wheel(got one), and have read about the Wicked Wheel. Now from my old days in the boat buisness, we would re-prop a boat with a higher pitch to move more water, thus making the boat go faster.
Pitch on a prop is defined as the amount of distance the propellor will move forward in a revolution. more pitch = higher velocity of medium moved.
I also have read about how over 25psi boost we are just super heating the charge air, and our turbos lose efficiency. Why? is it because of the pitch on the exhaust side wheel, or is it just heat soak from the higher EGT's that it takes to move the compressor side fast enough to produce more boost.
I guess my ? is are the stock blades designed for optimum efficiency, or is there a higher pitched wheel on the market that can acheive greater boost from our stock turbo's. Does the pitch on the exhaust side need to be more to turn the compressor side faster?
The WW by design cannot acheive more boost than that of a standard wheel because of the less surface area of blade faces.
Yes, I know I can go buy a new drop in TN, BB, H2E, etc..., but is there a less expensive alternative by just replacing the stock wheel with a wheel that is designed to move more air.
If a wheel was available that fit our turbos, and moved more air, how much lowend would we be giving up? Do we need an low pitch exhaust side wheel that is moved faster by lower volumes of exhaust, and a higher pitched wheel on the comp. side that is moving more air because it is turned faster by the lower pitched (drive) wheel?
this ought to give Gene something to think about.
Everyone else, what are your thoughts?
The biggest problem with going over 25lbs of boost on the stock turbo isn't the compressor side so much as it is the turbine side. Drive pressures on the turbine side begin to spike way higher, causing a huge imbalance of pressures across the turbo. This is what kills the turbo and the thrust bearings.
Put a larger turbine housing (1.0 or 1.15) on the stock turbo, and now you can hit 30+ lbs of boost and still keep the turbo in good health, all with the same stock compressor wheel.
Originally Posted by nlemerise
Curtis...if he raises the A/R ratio to 1.15 won't it begin to kill off low end boost (slow to spool)? I'm just wondering out loud, trying to get my mind around turbocharger basics.
The smaller the housing, the quicker the spoolup, but you sacrifice the top end performance because the smaller turbine housing becomes a bottleneck. That's why our trucks have a wastegated turbo to help bleed off some of that drive pressure and protect the turbo.
With a larger turbine housing, boost pressures drop on the low end and the turbo can become laggy. However, at higher boost levels you get a reduction in drive pressure as well as EGT's.
The .84 housing that comes on the Superduties is about as small as you can go without creating serious EGT issues. Once you start adding more fuel, the .84 housing becomes way too small and a turbo upgrade is often needed.
BTW, vans with the PSD come with a 1.15 A/R turbine housing.
Yep, I am with you Curtis and understand those basics of the Turbo, but to my original question, would a lower pitch drive wheel alleviate the the stresses because it would provide more torque to the comp. wheel with a higher pitch to flow more air. If you flow more air then you are creating more drive pressure due to the exhaust flowing faster. It is an endless loop cycle, but, what is terminal velocity before you start melting and over stressing the bearings?
Originally Posted by indebt
If You Get A Van Tubo What Are Some Of The Things You Need To Change If Any? Does The Exhaust Bolt Up, What Affect Does It Have On Towing Etc.
But I do know what you are talking about with the boating analogy. Change the pitch of the props and you get a boat that responds differently at low and high speeds. What kind of change it would make with a turbo???? Who knows . But, I think I might have another analogy.....
Rev the boat motor too high, and you blow the engine. Doesn't matter which prop you have, one prop might allow you to have a bit faster top speed, but in the end the engine has the ultimate limitation. Same for a turbo. The limiting factor is the exhaust drive pressures. Change the compressor wheel, but that turbine side can only flow so much exhaust gas before something goes boom. If you want a faster boat, put in a bigger engine. If you want more boost, put on a bigger turbine housing and add some fuel.
I guess that's my 2 cents...... for what it's worth Hope I made sense.
... this ought to give Gene something to think about ...
The following quote from Banks about the differences between the turbos is why I think each wheel has some unique design features that are tailored for their respective turbos. I can tell you with absolute certainty that the 99.5 wheel IS NOT designed for and will not work well with an early 99 turbo, even though somebody decided to start rebuilding the old turbo using the new wheel. A 99.5 wheel just doesn't work worth a darn on an early 99 turbo, and I had mine removed at my earliest opportunity which was 300 miles. When you read these quotes from Gale Banks regarding the WW and surge, remember that his Banks wheel = WW=OEM Early 99 wheel, they're all just a stock wheel from an early 99 turbo.
Ford-Diesel.com: What did Ford change in the turbo on the 1999.5-up Power Strokes? What is “compressor surge,” and how can it be fixed on these trucks?
Gale Banks: There are a few notable differences between the turbo design of the ‘99 (early) and the ‘99.5-up (late) trucks. To begin with, the compressor housing size (A/R ratio) changes from a 1.10 on the early turbo to a 1.00 on the late turbo. The diffuser face inside the compressor housing increases from a diameter of about 5.5" to about 6.0". The compressor outlet diameter increases by about 0.400". These changes account for the difference in physical appearance between the two. In addition to these changes, the compressor wheel itself is of a different design. Unfortunately, under full power operation, the late-style compressor occasionally goes into a condition known as compressor surge. Surge is an instantaneous reversal of airflow that occurs as boost increases at a fixed airflow. This can even occur on a stock vehicle under heavy load. Every compressor has a point at which it will go into surge. When viewed on a compressor map, the limitation of the compressor is called a surge line. Higher levels of boost will require a compressor wheel and housing combination that has a higher flow range before hitting the surge line. Figure 1 demonstrates the difference in the surge line of the factory wheel and the Banks wheel. When a compressor goes into surge, the only remedy is to reduce boost or change the compressor wheel. Our Git-Kit and Stinger levels moderately increase airflow (moving right along the X-axis) and stay below the surge line as boost is increased, so a replacement of the wheel is not necessary. Stinger-Plus and PowerPack® require the wheel because the turbine housing allows for an increase in boost that oversteps the stock surge line.
Your boat propeller analogy is better suited for the turbine, because there the exhaust gas flows straight through. My quote below is from the so called "vortex of doom" thread, and in it I see your boat prop as being more like the jet turbine fan ot the radiator cooling fan analogy I used.
Originally Posted by ernesteugene
... the turbine fan at the front (shown in green) is a lot like a radiator cooling fan, and the turbine fan shown here Click for full size image of the turbine on the hot side of our truck turbo. For this type of fan, the incoming air passes through the front of the fan and continues on out the rear,...
...On the other hand, the compressor wheel for our truck turbo shown here Click for full size image , is a centrifugal air compressor, and it has a much different air flow geometry than for a turbo fan. Centrifugal compressors work by using a vaned wheel that looks somewhat like a flattened fan, but air does not flow through it and out the back side as is the case for a conventional fan. This type of wheel imparts a twist or spin to the incoming air stream, and sends the air streaming outwards from the center of the inlet. The compressor wheel needs to spin at over 100,000 rpm in order to sling the air molecules to the perimeter of the wheel with enough centrifugal force to build the boost high enough to get good air flow through the turbo, and into the engine ...
I have what might be a dum question but I know very little about turbo set ups wether it is a gas or a deisel but I know this guy that has a trubo 6 grand national and he is injecting methonal to help cool intake temps which in turn cools exhaust temps??? which produces more dense air charge creating more power can this be done with a deisel engine? If so wouldn't this help your EGT's
