Marine 427 the good and the Bad
#46
Originally Posted by Bear 45/70
Still makes no sense money wise and everyone says this was a money deal.
If they didn't alter that for reverse rotation, there'd be lots of oil in the bilge...
I can't imagine machining the grooves the other way added a significant amount of cost to the crank... unlike the cost of the cam.
And remember, these weren't automobile engines, they were marine engines.
Anyone running twin 427's had enough money to pay the extra few $100 for the reverse motor
#47
It's true the hatch /////// marks went the reverse direction on the marine reverse rotation crank. Wish I still had them here to show you. My bud took the reverse rotation crank and smoothed the //////// oil slingers till smooth. Then used the newer rubber seal vs the older rope seal. It still leaked LOL. He changed out the seal for a rope one and was worse. Then put another rubber seal in and lived with it. This has to be well over two years ago by now. G.
#48
Think about it. if the grooves they put on all cranks back then were angled to pull oil back in toward the inside what do you think would happen as soon as they fired up a reverse rotation engine? They would have to reverse the angle or have oil spraying outh the rear of the block. Common sense goes a long way.
#49
#50
#51
#52
About 10 years ago a friend got a good deal on a running 427, we installed it in his F250. Wouldn't start, bumped it rolling backwards in 3rd gear it started. He had 4 speed reverse and one forward, fan blew air forward. Changed cam, dizzy and intake, ran great for years but always had a weeping rear main seal leak even after three seal changes, rope or rubber. If you think the hash marks are not important why did Ford make them for different engine rotations, enjoy your oil leak.
.....=o&o>.....
.....=o&o>.....
#53
What I'm saying is that if you are trying do do something as a money saver, a different crank isn't the smart way to do it. I didn't say the hash marks don't work. However if you are feeding pressurized oil to the rear main brg (they do) and the seal should retain that, why would the hash marks improve that, even a rope seal?
#54
I remember reading something about this on Net54. IIRC it's the same crank with a minor variation in the same machining process. I think Ford did that as an oil control measure-move oil away from the rope seal.
It's all trivia to me. It's not likely that I'll ever see one, much less own one.
#55
Originally Posted by krewat
I guess you can't get Crane or someone to machine one out of an FE blank?
INTERCEPTOR made a marine 427 that had 300, 330 and 400-hp. I think the 300 hp version was the same as the Chris Craft version, but not really sure.
P
#56
regards, P
#57
428T-bird
53
09-04-2017 07:17 AM
chukar
07-02-2017 08:57 PM
old farmer
09-26-2016 08:19 PM
66_in_ky
21
10-05-2010 12:41 AM
