How many D66 owners out there?
Originally Posted by RocknXJ
My '97 is stock except for a Banks 40hp chip and a Banks dp, and it's hitting 15-18 lbs of boost.
With stage II's (no programming) and bigger nozzles I can easily clear 22 lbs.
The HX50... Idk... It's currently sitting on my kitchen table as a center piece until I can get time off to install it.
Just some advice.. if you start running the higher lbs... make sure you have your intercooler boots tight. Don't want any of your older guys to have a heart attack when one blows off at 35 lbs!!! haha!
Glass.. I've had it happen to me twice now...
The first time.. about 3 in morning after I installed it and then a couple months after when I really layed in her pulling a pretty good load. I finally wised up and learned that you have to tighten the crap out of those clamps.
I probably have a couple small leaks. My hot pipe is cockeyed a little bit and thats the one that would always blow off. I'm gonna find someone with a mandral bender when I do my new ones for the hx.
Blowing a boot scares the crap out of ya. Sounds like someone pulled the trigger on a 12 gauge in the cab. lol
Glass.. you make me want to drive to NJ to ride in your truck.. Its about time I start working on mine...
My buddy in MD has a 96 F250 and he sent me his dyno sheets... Running 600 hp and 1200 lbs torque... That thing is a monster. Hopefully i will be there soon. All i need is a D66 and better fuel system and i should be good.
#29
Is it possible to build these trucks to 600hp and still have them be a daily driver? I need a truck that can hold the road in rain and snow, be reliable, not have spiking EGTs when towing, and get good fuel mileage as a daily driver. Is this a little far fetched? My initial plans for the truck are about 450hp.
