Gauge Needles vibrate when truck is turned on. Help!
2004 F150 Supercrew
44400 miles
So I turned on my truck today and the needles acted as if they were possesed. The went under the "starting points" and vibrated there for about 5 seconds or so... Very strange.
I also have been getting sluggish power from the truck. Mainly between 2000 and 3000 rpms.. Sound like a diesel at times.
Any ideas?
44400 miles
Any ideas?
Originally Posted by Foxxx
is the check engine light on? when was the last time the plugs have been changed? what about the oil? sounds like something is either going bad and needs replaced, or you need a tune up...but seriously check your oil cause sounding like a diesel on a mod motor is NOT a good thing...
Plugs are original. I didn't think they needed to be replaced soo soon.
Oil change is due late this month. It was changed last by the dealership.
The only "check engine" light I had was on July 21st. It was P0119. "Engine Coolant Temperature (ECT) Sensor Circuit, Intermittent or Erratic.
I cleared it and it has since not come back.
Fuel Filter was changed between 25k and 35k I can't recall when though.
Originally Posted by last5oh_302
As far as the jumping needles go, I'd say you're due for a new battery.
My ondash voltmeter reads fine when my truck is on. I'll go outside right now and read the battery charge when it's off.
Here are my readings using a FLUKE 75 Series Multimeter:
Truck ON: 13.65
Truck OFF; ACC ON
Radio OFF
(Switch OPEN): 12.37
Truck OFF
Door Closed
ALL Dome lights OFF
(Switch CLOSED): 12.62
Do these readings raise any warning flags?
The gauges moving and shaking like that was the cluster recalibrating itself. It usually only does this when it’s lost its calibration data. If it just happened that one time I wouldn’t worry about it too much. If it’s doing it a lot then I would say time for a new battery because it’s often a sign the battery isn’t providing enough power for it during cranking. As far as the sluggish power I would say if you haven’t changed your fuel filter recently start there. All your numbers really tell me is your alternator is working.
Thanks!
It's really wierd to watch the needles perform this way. Reminds me of a Turbo/ Vac gauge when there is no boost and a vacuum exists..
I checked the "eye" on the battery and I can barely tell a faint green color. Should this "eye" show a vibrant green?
What is the normal "charge" for our batteries?
hmm.. I might need to add the new battery to the tuneup.
Let's see if that solves the issue. Tomorrow, I am going to change the oil, fuel filter and add an additive to the gas to remove any moisture. I'll also drive over to the auto parts and grab a new battery.
I just finish cleaning my K&N Air Filter. So once I finish those few things tomorrow, I'll be better able to gauge what's going on..
I'll let you know.
I'll let you know.
