Oil drain plug torque specification
Old 08-17-2007, 07:29 AM
cumberlandboy's Avatar
cumberlandboy
cumberlandboy is offline
Hello. I've been looking around the web for some time and still can't find the torque spec for the drain plug on my 2000 7.3L diesel F-250 Superduty.
Anyone know the numbers? Thanks in advance.
Old 08-17-2007, 08:36 PM
F350-6's Avatar
F350-6
F350-6 is offline
I just tighten mine till it feels good and tight. I've had no problems so far with this technique.
Old 08-17-2007, 08:45 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
not too loose but not too tight..i give it a good snug..now i have the drain valve..just a flick of the switch and she is draining http://www.dieselsite.com/index.asp?...PROD&ProdID=33
Old 08-17-2007, 11:16 PM
Douglas DC-9's Avatar
Douglas DC-9
Douglas DC-9 is offline
I don't know what the specific torque needs to be, but I' guess around 60ft.lb would be just fine. All you really need is enough so that the plug doesn't unscrew.
DC-9
Old 08-17-2007, 11:24 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
DC-9
Agreed, and so that it doesn't leak either. My Fumoto arrived today. I am in for my last messy change. My pan holds 10 quarts. Do the math. I may begin to enjoy the oil change like in the wife's truck.
Old 08-18-2007, 06:11 AM
cumberlandboy
Thanks everyone. I did finally find the torque spec after talking with a Ford diesel technician: 23 ft/lbs.
And if you strip it you'll need to replace the oil pan which apparently requires that the engine be pulled. OUCH!
Old 08-18-2007, 06:17 AM
ron's power stroke
i didnt think it was that much...like i said..give a good snug...if you strip it you can retap for the next size up..or like a friend of mine did..he welded on a nut...
classic4x4
09-19-2007 02:38 PM
tchad07
Oil & Lubrication
15
07-30-2007 10:30 AM
tchad07
1978 - 1996 Big Bronco
05-09-2007 09:36 PM
tradosaurus
03-03-2007 10:40 PM
phre2b
36
01-24-2007 12:42 PM
Quick Reply: Oil drain plug torque specification
