still a slight hesitation
Old 08-11-2007, 12:33 PM
9902ford's Avatar
9902ford
9902ford is offline
Hello everyone,
I just did a tune up on my 99 f150 4x4 5.4l. Here is what i did.
Fule filter
Air filter
Oil change
Spark Plugs
The old plugs looked to be original Motorcrafts and the gap was like around .60. The driver side was the worse, i couldn't do it without moving the fuel rail to get to the back two. After doing everything the truck is running good, but there is still a very slight hesitation when i take off from a stop. I just added some fuel injector cleaner to see if that helps. I am thinking about cleaning the MAF sensor and i also noticed the Throttle body intake looked a little dirty. Any thing else that i should look at?
I would also like to thank everyone on here, this site has alot of great info that has helped me alot. Especially the sqeaking front end problem i had with the lower Ball Joint
Thank you
Old 08-11-2007, 01:04 PM
bigblock_drock's Avatar
bigblock_drock
bigblock_drock is offline
yes try cleanig the MAF
Old 08-13-2007, 09:25 AM
9902ford's Avatar
9902ford
9902ford is offline
Well i drove the truck to work the other day and on the freeway it started to stumble a little. I would be doing about 60mph and just barely give it some gas and it would start to hesitate and kind of shake a little until i put the gas pedal down further. It only seems to do it if i am just barely pushing down on the pedal. Now it did this a long time ago and i noticed that there was water on the back COP on the passenger side. Now i did have the AC on for a bit and i started it doing it but it has also done this when i wasn't running it. I wonder if it could be a COP issue?
Thank you
Old 08-13-2007, 11:29 AM
wtroger's Avatar
wtroger
wtroger is offline
A notorious problem on the model ac water on cop. Did you replace that cop and boot.
f350hammer
07-22-2014 10:14 PM
f350hammer
General Automotive Discussion
07-22-2014 05:43 AM
birddog1$
2004 - 2008 F150
11-15-2011 04:00 PM
Crazz
19
08-07-2004 10:45 PM
flashover152000
3.8 & 4.2L V6
17
12-02-2003 07:30 AM
Quick Reply: still a slight hesitation
