Help!!!
Help!!!
Okay, In all packed for vaction and In backing in my parking spot and the steering wheel makes a plastic like snapping sound and now it feels kind of loose. It still turns but seems to catch in some spots. The wheel adjustment part seems to work fine it seems like it is above that, I pulled the cover off of the wheel and the trim from around it but I dont see anything out of the ordinary. Does any one have any suggestions? Eirik
First of all have you noticed the wheel being loose before today? Hole the wheel with one hand on the three o’clock position the other on the nine o’clock. Can you feel play in the wheel when you push and pull in a rocking motion? Try the same in the twelve and six position. If you cant’ feel any play the noise could be many things from a piece of plastic trim rubbing to the direction signal inside the column.
Justin
Justin
look up under where your knees usually are, you should see a U joint and right before that there should be a small metal wheel whith a bunch of holes. When i wiggle that u joint I do not have any play on my truck, check yours out at the same joint and see you can isolate where any movement is coming from. The other thing to check is there are plastic parts that catch for the Multi function switch (turn signal) it is possible one of those hung up and popped or broke.
The wheel needs a puller to come off after you remove the center nut. If Utahcrew is correct then I would go on Vacation. Keep in mind that it does catch every now and then so be careful. I would imadine you won't get much wear while traveling since the wheel doesn't turn much on the road. I wouldn't let it ruin my vacation but always keep it in the back of my mind. Also don't put excess wear on it while parking, take it easy and don't turn it all the way. Hey you might find a good junkyard in Oregon while you are there.
Okay guys, in the name of keeping you informed. First off, thanks to all for the great, immediate responses. Your all a good group of guys. So back to the problem. utahcrew hit the nail on the head. I got the wheel off and found the bushings and bearings to be bad. Parts from ford were less then 25 dollars and I think Im on my way. I got to tell you, Im really not much of a mechanic, just cheap. Thanks again for all your help. I hope this is the last of the trip drama. Eirik
52'F-3
03-27-2007 04:21 AM
