When Did 5.4 Go From 235 hp to 260 hp
I just purchased a 1999 F 250 Super Duty. I have read that starting with the 1999 models, the 5.4 engine was increased from 235 to 260 HP. But, my owners manual, which was purchased in March 1998, indicates the 1999 truck has 235 HP. The truck was actually made in September 1999. Is there any way to look at the engine and tell which engine version I have? Any help would be appreciated.
Real easy there John, Take your front passenger wheel/tire off (follow safe and proper jacking/lifting safety proceedures) poke your head in the fender well and with a flashlight look at the cylinder head casting numbers (they are on the passenger side towards the front just above the first two cylinders and are approx 1/4" tall alpha numeric) you are looking for the letters PI
My 99 Expy has it.
My 99 Expy has it.
I have a 1999 F250 Lariat 4X4 and it has 235hp no doubt! I'm telling you, this thing is a dog! I had a 2000 F150 XLT 4X4 before this one which also had the 5.4L; however, it clearly wasn't the same engine. Believe it or not, the 150 was quite a bit quicker than my 250SD. I know one thing for sure is different. The oil filter on the 235hp 5.4L is more towards the back, and the 260hp 5.4L oil filter is in the front driver's side part of the engine. I will always remember what a pain it was to change the oil filter on the 2000 5.4L. The oil always drained onto the front suspension plate. The 235hp 5.4L doesn't have this problem. It drains easier!
>The 5.4 was 260 hp in 99 but only in the F150's
>In 00 they put the 260 hp 5.4 in the F250/350's
Nope.
All 99 f150 5.4L were 260 HP
Ford 'used-up' the remaining supply in the Expedition and SuperDuty trucks with the units 'running-out' in late June to July of '99
if you have any dought as to which 5.4L you have check the 'build' date and if yours was built in June or July of 99 check the head casting number to be sure
Nope.
[updated:LAST EDITED ON 18-Sep-02 AT 06:55 AM (EST)]1. for the most part, through the better breathing cyl heads
2. you could install headers, CAT back exhaust with new Y pipe, a FIPK, a dual 16" electric fan kit and maybe pick up most of the 25 hp
Drum-guy
16
07-12-2020 09:28 PM
