Part throttle power loss/surge with carb
Originally Posted by Franken-Truck
No, the 2 big posts. . .
I had someone turn the key trying to start it while i had a volt meter coming from the red wire that activates the solenoid to ground and got 0 voltage It's always something. . .
From you description it is either the ignition switch or the clutch or neutral switch.
Originally Posted by Bear 45/70
From you description it is . . . neutral switch.
I feel stupid now, thanks
Never got the chance to check fuel pressure today. . .
Curious, are the fuel pumps suppossed to be noisy? I mean, like old gear drive pump noisy?
Uh!!! I just realized the column shifter is lose, and I jiggled it and it turned right over
Have the pumps every been run dry?
I would agree with assessing your fuel pressure. If it doesn't have a regulator I suggest go buy and adjustable one and fit it and while you're changing stuff you could put a in-line gauge just after the reg. Also check your needle and seats and bowl float to make sure they are operational.
Regards
Brad
Regards
Brad
Kyre Searcher
25
07-29-2016 05:30 PM
Tkc432
06-18-2015 01:15 AM
Franken-Truck
17
12-25-2011 03:11 PM
