Colder Thermostat
Not really. I would address the knock. It can usually be caused by clogged EGR ports in the intake. Verify that your EGR system is working. At an aile, apply vacuum to the EGR valve. The engine should start running rough or die. If not, the ports are probably clogged and causing pinging.
You might also clean the MAF. If dirty, it can cause it to run a bit lean and also cause it to knock.
hwknsdrag
01-11-2012 06:35 AM
