Rear disc brakes
Rear disc brakes
Anybody used the rear disc kit on www.tsmmfg.com ? I was thinking about getting it seems kinda pricey i think
Originally Posted by Dean88
I've heard that the rear disc's off of an explorer will fit all 8.8's.
https://www.ford-trucks.com/forums/5...onversion.html
As I mentioned in this post, the way I found what I did was just going back page by page. It has been suggested to go out to Google or another search engine and use it to search ford-truck.com but I can't seem to frame my query correctly to be productive.
Also after this thread I called Currie tech support to ask what they were using for their conversion & was told it was a modified 2001 explorer set up to use the Torino bearing, which brings up a new set of questions.
Good luck, will be watching for your success.
There are after market backing plates that use explore or stang rotors that will have to be redrilled. Also the Parking cable & brake system is a mix and match of parts to get to work. But basically with our wieght distribution on trucks .
I'd just get a set of vented front rotor for front and call it a day . My friend Had a kit on his F150 (He died in accident) But He had a adjustable valve for rear Because he could get to work right . And with no weight on back it just slide tires or seem to do nothing any way. But I know of several on site post of installs.
also, you would need two spare tires.
This site can be searched on Google by typing your keywords followed by: "site:www.ford-trucks.com"
using various combinations of, disc+brakes+conversion+explorer+8.8+site:ford-truck.com
yields me nothing but installs on 54-72 truck, slotted front upgrades, reveiws of explorer brakes & other non-apllicable listed tech articles. I can't seem to make it search the threads.
elusive info
Originally Posted by lostin90s
Sorry I read several posts.
Still no joy. I guess the correct year explorer brake backing plate will remain a mystery to me for a while longer despite how common the knowlege supposedly is...
Scndsin, I know for sure that a friend's 96 V8 explorer had rear discs with an 8.8" rear. I'm sure this setup was not only used in 96, but I don't know the exact years. The rear discs could have started as early as 95 (new model was released in 95), and may have stayed the same up until Ford released the independent rear suspension-equipped explorers, maybe around '02.
Take a look at this mounting
https://www.ford-trucks.com/user_gal...=60308&width=0
The design of the 95 explorer up till (?) is a rounded diamond till it changed to rectangular mount (As shown here) like what is used on the f-series 8.8.
This user mentions in another gallery pic that he had to use 2 right side hoses from a 98 explorer, but doesn't mention if the whole set up is from a 98 donor or not. I haven't been able to lay hands on a 98 part or pic to verify. I do have a 95 service CD with the illustrations showing the discriptions that I mentioned above.
My other 3 questions about the conversion are what proportioning valve was used? Was the master cyl changed out for a larger unit? (Pob'ly what Lost's friend's problem mentioned in post #6 was) And how the parking brake cable mates up.
