inccorect timing?
inccorect timing?
A couple of months ago i perchased a 72 f 250. The previous owner had swaped the old 6 cyl out for a 460 and c6 but the camshaft went out and i supposed he no longer wanted to bother with it so he sold it to me. I replaced the cam with a performance cam. i am not sure what the lift is on it but i do know it is more than the stock one at around .5". after some truobles with the tranny caused on my part i have got the truck running. i go to time the truck by ear just to get it going at first but when i timed it to 10btdc the idle speed decreased. it does not backfire but im curious as to why 10btdc does not produce the best engine idle. could it be that turnig the distributor advances the timnig causing the engine rpm to increase? i did pop the valve cover off and set the balancer to tdc and both valves on the #1 piston were closed so i believe i did the cam instalation right. i read another article in which another guy with a 460 said it did not turn over well while starting and someone suggested the timing could be off. my 460 also seems to be sluggish in starting but i figured this to be the fault of my battery which i dont think is very good anymore. i'm wondering if anyone could tell if i have a problem in my camshaft alignment or if a motor will naturally increase idle speed if the distributor is moved passed 10btdc. Any suggestions on this would be greatly apreciated.
Originally Posted by Bear 45/70
How much Cam? Too big a cam will screw everthing up for stock settings.
Half an inch is ALOT of of lift for a cam. Like darrin1999 said lobe separation and duration have alot to do with idle. A " fat " cam will produce a very lumpy idle. Depending on duration you will have to adjust timing accordingly. Also did you install the cam cam straight up or advance or retard it. Just for example I have a 73 Ranchero with a 351C. I installed a comp cam with .480" of lift and it puts out just over 400 hp. I would not trust your micrometer to much on a cam.
Post Script.
I installed my cam with 4 degrees of advance and my initial timing is set at 5 deg' btdc. Where as the book calls for 8 deg' stock. I have a 9.5 to 1 compression ratio And yes my idle is lumpy but the truck is very fast and will blow corvettes away off the line. Even though a 351C is more of a top end engine.
Originally Posted by 460in503
Post Script.
it sounds like your cam may have advance ground into it and/or has too much duration and/or you have other engine issues... you need to get the cam card for the cam or at least the brand and part number so we can look up the specs and tell you wether it should have a rough idle or not. 10 degrees is just a safe starting point. 10 degrees initial and play with it from there. make sure the advance is disabled when you set base initial timing.
