no cup holders... no holders of any sort!!
Old 07-10-2007, 09:30 PM
jimmythesaint5897's Avatar
jimmythesaint5897
jimmythesaint5897 is offline
help, iv got a 92 regular cab 5 speed. bench seat. does anyone know of where i can get a bolt on console for the floor in the middle, or is my only option to replace the seats or get one of those cup holders that hangs off the side of my door?
Old 07-10-2007, 10:04 PM
frederic's Avatar
frederic
frederic is offline
Kmart, target, and others have "floor hump" coffee holders that often times have places for change, cassettes, etc. $10-$25 depending how fancy you want to get. Nothing wrong with bolting one of those to the floor.
Old 07-10-2007, 10:46 PM
dj250's Avatar
dj250
dj250 is offline
Well you have a 5-speed bench seat, what do you expect? Not much room there. I know what your talking about I have the same thing. I'd say the door hanging cup holder!
Old 07-11-2007, 05:47 AM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
There is a "cup holder" made for your seat........I just looked on Ebay and didn't see any........but usually there are a few up for sale.........Check on "car and truck parts-Interior-cup holders". The one I'm talking about bolts to the front of your seat.......rather small so your shifter doesn't hit it....holds 2 cups and has a map holder in front I think.
Most of the aftermarket ones hold more stuff.........and like has been said.......couple of sheet metal screws and it's in.
Good Luck
Bob
Old 07-11-2007, 06:19 AM
Skandocious's Avatar
Skandocious
Skandocious is offline
Well first he needs to make sure that his seat has the metal posts on the front Bob. I think you can get install kits for this but I can't say whether or not they work very well (or if they work for all seat applications). Also, your statement about the cupholder is incorrect to the best of my knowledge. The cupholder that you're describing with the 2 drink holders is only going to fit in an automatic. There is a special cupholder which bolts to the same posts that was made for the manual transmission trucks; it only has 1 drink holder spot and a small tray for placing change, etc into.
Here's the cupholder for the automatics:
Here's your manual transmission cupholder:
And here's a guy on ebay that I bought my OEM cupholder from!
http://cgi.ebay.com/ebaymotors/TAN-92-96-FORD-TRUCK-VAN-CAR-OEM-SMALL-CUP-HOLDER_W0QQcmdZViewItemQQcategoryZ63691QQihZ019QQi temZ8005734879QQtcZphoto
Check out his other auctions, he has all different colors. I had to paint mine because he didn't have gray. Good luck!
-Chris
Old 07-11-2007, 06:45 AM
92F150Flare
Thanks Chris.........I was trying to describe it from memory.........which ain't all that good.......I'll try to do better
Old 07-11-2007, 06:55 AM
Skandocious
No worries man You were on the right track.
-Chris
Old 07-11-2007, 09:06 AM
toddol1971's Avatar
toddol1971
toddol1971 is offline
I'll give you the idea that I'm gonna use. I will get a piece of 3 or 4" pvc pipe. I will take my usuall cups with me & may use 2 different size pipes to accomodate cups more better. Like my wordage? LOL. Anyways, cut to size, cut slots in top edge for handles then bolt with a large washer thru bottom to secure to floor. You can insert a piece of foam of some sort to fit how deep the cups sit in there. What do you think. You can paint it to match too.
Old 07-11-2007, 09:20 AM
BChance's Avatar
BChance
BChance is offline
I went this route..
http://www.sportsmansguide.com/cb/cb.asp?a=134961
Works great, removable, and an armrest to boot.
Old 07-11-2007, 03:40 PM
msb71's Avatar
msb71
msb71 is offline
Hey Chris did your truck come with the "2 cup holder" when you got it? , mine has the second one you showed there it is mounted to the back seat. Be nice to have the 2 cup holder .
Mike
Old 07-11-2007, 04:55 PM
19FORD93's Avatar
19FORD93
19FORD93 is offline
I have a red cup holder pictured above as the manual. Has one cup holder and a bigger area for storage or something, not really sure. I bought an aftermarket one at wally world but if you want a factory one i'd be willing to sell it to ya.
Old 07-11-2007, 05:46 PM
Skandocious
Mike, my truck didn't come with ANY cup holder from the previous owner. I bought mine from that guy selling the cupholder on the ebay listing I mentioned above. $27 after shipping I believe.
-Chris
Old 07-12-2007, 01:30 PM
jimmythesaint5897
hey guys, preciate it!
Old 07-14-2007, 07:30 PM
misfit351's Avatar
misfit351
misfit351 is offline
i just took an old one that held 2 and cut it flush across the back and it fits up against my seat and the shifter don't hit it or anything.its not pretty but it works
Old 07-14-2007, 07:36 PM
MrRogers's Avatar
MrRogers
MrRogers is offline
I just cut 2 holes in the armrest and went to the junkyard and pulled 2 plastic cupholders out of some junk van. then, i just put glue in the hole and presto chango; 2 cupholders that don't get int he way at all. It works. However, if someone does ride in the middle the cupholders are useless.
Josh
Quick Reply: no cup holders... no holders of any sort!!
