Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2009 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-15-2007, 04:39 AM
skinner00 is starting off with a positive reputation.
Unhappy My New '08
well bought an '08 yesterday, drove it home (it was great). drove to work today and notice a huge puddle of atf on the ground after the truck sat for awile. i could see it dripping from the bell housing. had it towed to the dealer, they said it is the front seal on the trans. so I had it for less then 24 hours, now it is going to sit at the dealer until monday. not a good start, although i know stuff like this can happen
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-15-2007, 08:18 AM
280fx is starting off with a positive reputation.
Sorry to hear that, hopefully they can quickley replace that seal and have you back on the road in no time.
  #3 (permalink)
Old 07-15-2007, 03:59 PM
SouthTexasDiesel is starting off with a positive reputation.
Good mechanic can do it in about 6 hours with good help and all the parts on hand. Had the same thing go wrong in my 03' with 80,000 miles. Be happy it's under warranty. That little $2 seal ended up costing me over $1100 to replace. That's one of the reasons I ended up with a 6-speed on my 08'. Sorry to hear about that, good luck in the future. These trucks have been doing pretty good so far.
__________________
08 F-350 Cowboy Edition 6.4 4x4 CC DRW 6-speed w/3.73 gears
Programmed with SCT LiveWire with DPF delete tune
Full 5" DPF & Cat delete pipe from Bay Area Diesel
6" Aussie stacks painted black
Random other goodies
  #4 (permalink)
Old 07-15-2007, 08:15 PM
i agree, the 50 or so miles I put on it were awesome.
  #5 (permalink)
Old 07-15-2007, 09:12 PM
SpeedE55's Avatar
SpeedE55 is starting off with a positive reputation.
It sucks, but I wouldn't worry too much about it. My first 6k miles have been trouble free.
__________________
2008 F450 (SOLD)
2008 GMC Sierra Denali
2007 Range Rover Sport Supercharged
2006 F250
1967 427/435 Corvette Convertible
  #6 (permalink)
Old 07-15-2007, 11:46 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Yeah hope it gets fixed yeah it just might be a little quirk that it came with from the factory at least i hope so for ya
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #7 (permalink)
Old 07-16-2007, 01:28 AM
SuperDutyJ4500 is starting off with a positive reputation.
They should take good care of you. So far, they have taken care of the issues as quickly as possible.
__________________
SuperDuty's Rule..
  #8 (permalink)
Old 07-16-2007, 02:00 AM
one thing i have to say, which i was quite surprised by, was everyone was very cool. from the tow truck driver to the service advisor calling me before my truck was even picked up by the tow truck. my salesman even called me to make sure i had a ride home and to see if he could do anything for me. (and it was his day off) so far i am extremely happy, the only thing that worries me is was it caused by seal damage from assembly or was there something else that caused the seal to fail. I guess I will find out after they fix it
  #9 (permalink)
Old 07-16-2007, 07:34 AM
Quote:
I feel your pain, although my problem was not as bad as yours. I know this tends to tant your new car experience, but once it is fixed you will really start enjoying your new truck.
Just after getting my 2008 F-450 home, I noticed a small engine oil leak under the truck. I took it back to the dealer and it turned out to be a simple fix. The seal (oring) for the oil dip stick tube had been torn during installation, a simple fix but I had to wait a couple of days for them to order the part.
Let us know how everything works out. Hope you enjoy you new truck as much as I am mine.
  #10 (permalink)
Old 07-16-2007, 10:24 AM
chi6488 is starting off with a positive reputation.
Feel your pain. Drove my 08 around 20 miles and was in the shop for a week when they had the problems with the injectors. Truck runs great now.
  #11 (permalink)
Old 07-17-2007, 12:43 AM
Thumbs up
I talked to the advisor today. they removed the trans and inspected the trans seals and pulled the oil pump. they said nothing looked obvious but they replaced the seals and o-rings. I was told the mechanic was going to stay late and get it put back together tonight. Then check it in the morning for leaks. Which made me feel better because it was leaking even when the truck wasnt running, but i am skeptical about not finding anything obvious
  #12 (permalink)
Old 07-17-2007, 01:14 AM
The seal may have just been pinched or could have had a little defect. Good thing you caught it early and didn't drive much with it like that. I had to replace my torque converter when my front seal went out because I had to drive almost 100 miles to the nearest dealer from my ranch. By the time I got there it was pouring tranny fluid.
__________________
  #13 (permalink)
Old 07-22-2007, 03:38 AM
Thumbs up
It has been several days now and the trucks isnt leaking anymore. all I have to say is I love this truck.
  #14 (permalink)
Old 07-22-2007, 11:44 AM
Big Sky Rancher's Avatar
Big Sky Rancher is starting off with a positive reputation.
Good to see that a bad situation was handled efficiently and had a happy ending. Thanks for the report, skinner00, and best of luck with your new truck.
  #15 (permalink)
Old 07-22-2007, 12:38 PM
Glad to hear that you're good as new again, enjoy!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
