2007 expy radio removal?
Old 07-10-2007, 10:56 AM
trpltongue's Avatar
trpltongue
trpltongue is offline
Hey all,
I'd like to install a new nav unit in my expy but I can't seem to figure out how to remove the old head unit? I want to remove it to see if the rear dvd works without it in place.
Thanks in advance,
Russell
Old 07-13-2007, 10:18 AM
trpltongue's Avatar
trpltongue
I know this forum is slow, but since I didn't get a response I went ahead and just started pulling on things and this is what I found out:
To remove the radio, first remove the small bezel below the main radio bezel by prying the top back then pulling out towards you. This is a bit difficult as it is very snug in there. Then, starting from the bottom, pull the main radio bezel out towards you. Again it takes some muscle as it is a tight fit, but it will just pop out. Make sure you pull from the outsides only, as that is where the connectors are, and be gentle
That's it.
Hope that helps someone in the future!
trpltongue
09-28-2008 09:34 PM
ehumaui
1966 - 1977 Early Broncos
04-05-2004 12:17 PM
Russell Leonhardt
09-11-2000 09:27 AM
Russell Leonhardt
08-06-2000 06:04 PM
Russell Leonhardt
08-24-1999 06:25 PM
Quick Reply: 2007 expy radio removal?
