transmission cooler lines run through radiator?
Pop,
My Van is a May 1, 2000 Build also, at the Lorain, Ohio Plant.
I ordered the van through Beshore & Koller in PA., the Ford Dealer
that supplies Quigley.
I have the small cooler at the end for the P/S, I think all Super Duty's have them.
The 4 Wheel ABS was an option in 2000 for the 7.3L Vans along with a "One-Up" Front Spring Upgrade. I got all the available options on my Van when I ordered it.
I'm sure the Trucks had the same type of options, or maybe not.
Do all the Trucks have the 4 Wheel ABS or was it an option?
Russ
Russ
Resurrecting this old post. Still overheating every summer. I put a new fan clutch on this last winter, I replaced the bypass valve last summer, I put in the highest capacity tranny cooler I could fit. Today it went up to 230 pulling up a hill.
I'm thinking I'll have a radiator shop put in a OTW radiator.
I had heard somewhere that a bad torque converter could cause the oil to overheat. Is there any truth to this? It locks just fine at highway speeds, so I'm not sure how it would fail.
Any ideas before I start sinking money into this thing?
That is the first thing to do if your tranny is overheating.
Now you're talking!
I don't think there is anything wrong with your converter. Install an OTW in the radiator and I think you'll have this problem solved.
Mark, Those of us that have performance tunes with some added line pressures should we worry about this bypass opening up too soon and causing excessive heat?? And what would be your recommendation, warming up the trans in the stock settings before switching to higher line pressures, tunes?? Just wondering.. Thanks Mark..Don't mean to derail a bit but just had to ask..
Well I have my truck set up with a deep tranny pan, and a cooler out of a 6.0 truck. I use royal purple fluid. I have ran it this way for 5 years using only the 6.0 cooler. I bypassed the cooler in the rad when the trans was replaced since it was full of garbage from a convertor / trans failure.
I can pull a 32' trailer with two jeeps on it all day long and my temps run at 180 even up steep mountain grades.
The only time I have been hotter than that is stuck on a 2 mile grade in construction. It was stop and go and about 90 degrees out that day. It got up to 230 for a couple of minutes at the top of the hill. Must have stopped and started on that hill 50 times???
#28
#30
Final report on this:
I had the local radiator shop put in a new radiator with OTW cooling. It helped. In the past, climbing up the mountain mentioned, the temperature gauge would register 250 degrees, which is the max the gauge will register, so it could easily have been a fair bit higher. This trip, the temperature only went to 230 pulling the trailer (about 4000 lbs), and 210 with the pickup alone not pulling the trailer.
The road is a bit difficult I guess because it rises about 2000 ft. in altitude in about 3 miles (after rising about 1000 ft in the previous five miles of decent road). The road is very rough with lots of switch backs -- I think I averaged around 8-10 MPH during the 3 miles.
Anyway, a significant improvement over the last time I went. Thanks or all of the help.
