New to bio and WVO
Do not get the idea that the chemicals are not dangerous. Such ideas are the source of carelessness.
Understand; however, that proper handling and safeguards will greatly reduce the potential for problems.
You can substitute Ethanol for Methanol, there are some problems associated with this substitution, mostly associated with the requirement for absolute purity. Additionally, you may run into problems with the Feds because Ethanol is the alcohol found in "adult" beverages.
You can substitute Potassium Hydroxide for Sodium Hydroxide (Lye), it is slightly less caustic and actually preferred by many BD makers.
You cannot change the need for an alcohol and an alkali because the chemistry won't work without them.
I am a chemical engineer, so my perception of a dangerous chemical may be a little different from that of the general public. I still say that fire presents a greater hazard to the OPs family than exposure to any chemicals used in the process.
Obtaining the pure ethanol that would be required would take quite a bit of the economic advantage out of home brewed biodiesel. I would stick with methanol. I think the sodium vs potasium hydroxide is about a wash.
Instead of purchasing protective gear a simple swamp cooler blowing at your back and out the garage will keep the fumes away from you and the family. Realistically its only as dangerous as storing gasoline in the garage. Wood alchohol will evap pretty quickly before being absorbed into the skin (in this heat). Monster (Rob) makes his in a lil shed with no problems at all. JUST DONT INHALE the fumes of the combined metholoxide and then in the veggie heating combo. Your heating with electricity with the garage open anyway and not any at night. (to protect your family) Just my pennies
derherr65
Bio-diesel, Propane & Alternative Diesel Engine Fuels
66
04-23-2007 08:23 AM
Orpackrat
10-14-2006 12:03 AM
Robert6401
08-11-2006 01:16 PM
