A REAL cold air box...and CHEAP!
#61
I'll admit I was wrong and that the air does move one way... Now that I recollect better... I was just remembering buying an aftermarket fan for a project and being asked if the fan pushed or pulled the air. But I wasn't asked if the fan was going on the front or back of the radiator either...
#62
#63
#65
That looks like it has possibilities-I used the outer shell from an old portable dishwasher to make mine! Poor boys got poor ways!
#66
well. It looks like it would fit it I pulled out the fluid reservoir. I didn't realize how far down it was to the wheel well. Problem is that the tube I have on there now is rigid and wont move. This setup would need the filter moved forward a little bid for the box to come all the way forward. Just cut a hole and I think the box would almost fall into place.
I might try this out on the 94 plow truck.
#67
#70
I don't remember if we talked about it or not, but I know a few people including myself that have had the same MAF KN setup and it did not seal up at the throttle body. I also don't like that setup, because that air temp sensor is exposed to the elements, cheesy design on that.
I know that my truck, as well as Jason's Lightning clone, and Cadillacmobs truck run better with the stock air box.
#71
He speaks the truth. You will lose tq and HP with that setup. My box put 10 HP to the wheel on back to back runs versus stock box. With hood closed by the way.
That's why we built the one diagrammed in this thread. To improve upon the original design from Ford, in order to gain true power and efficiency on a not so stock 5.0.
#72
GreatNorthWoods
21
10-10-2012 09:46 AM
jimmyb08SD
EcoBoost (all engine sizes)
04-25-2011 10:30 PM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
AF Mezkin
1997-2006 Expedition & Navigator
24
05-29-2006 10:31 PM
