Finally diagnosed the clunking in the rearend and its the passenger side wheel bearing. The only problem with that is I have no idea how to do the bearing or seals. So I was wondering if somebody had a link to step by step instructions on how to do it or a link to somewhere.
I would recommend picking up a Chiltons manual for the truck, it'll give you very detailed instructions and torque specs, which are critical in the rear diff. I'm not familiar with the 9.75 rear. You might do a quick search in the rear diff forum, further down the main index.
