Ford Part # for engine wiring harness
Old 03-25-2014, 03:30 PM
BarbToothaker's Avatar
BarbToothaker
BarbToothaker is offline
I have the lighting harnesses and the dash to gauge harness, with the generator to Voltage regulator wires, I can make the distributor to coil wire if need be. But It seems I am missing a couple harnesses, and I can't read/identify the part#'s from the catalog/CD I have. Seems like I need the harness to the Voltage regulator, and the one to-from the solenoid. Any Ideas out there?
Old 03-25-2014, 04:12 PM
schoo's Avatar
schoo
schoo is offline
63' f100 in garage?
Old 03-25-2014, 04:17 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I have the lighting harnesses and the dash to gauge harness, with the generator to Voltage regulator wires, I can make the distributor to coil 12216 primary wire if need be.
But it seems I am missing a couple harnesses, and I can't read/identify the part#'s from the catalog/CD I have.
Seems like I need the 14305 harness-generator to the Voltage regulator, and 14398 to-from the solenoid.
The 12216 primary wire (not shown in this pic, see pic of dizzy-page 756 and etc) can be purchased from any auto parts store. I-6 different from 292.
Old 03-26-2014, 09:04 AM
BarbToothaker
Yes been apart down to the frame and am reassembling doing preservation as i go. The wiring harnesses from the firewall out are shot.
Old 03-26-2014, 09:44 AM
schoo's Avatar
schoo
schoo is offline
You should contact camperspecial 65 he may have something
Old 03-26-2014, 01:51 PM
BarbToothaker
OK will do, Thanks Schoo
Old 03-26-2014, 02:51 PM
TA455HO's Avatar
TA455HO
TA455HO is offline
I was just texting CS65 and he says he has some 65-6 harnesses. Nothing for 63 from the sound of it. He is almost out of the parts biz altogether now. He told me he was going to smell the roses.
He might be able to get a harness from a '63 in the JY if it hasn't gone to scrap yet.
traveler1234
08-08-2017 09:16 AM
gangstakr
03-14-2015 01:28 PM
SC65F100
01-14-2013 04:45 PM
Chevmn56
01-02-2013 08:30 AM
Pitcrw6
08-26-2012 12:59 PM
Quick Reply: Ford Part # for engine wiring harness
