1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 Ford F250 Suoer &.3 Diesel Air Conditioning Problems
Old 06-12-2007, 04:19 PM
bridgeendfarm's Avatar
bridgeendfarm
bridgeendfarm is offline
Hello all,
I have a 2001 7.3 F250 that the ac works one day doesn't work the next, I have changed the pressure swith by the accumalator and the gas is good in it. Any Ideas, I looked into the fuse panel under the hood for a relay that either controls the clutch or compressor and they are just numbered so I swapped the ones that had the same numbers around it made no difference, It still sometimes it works sometimes it doesn't. There is no clutch slippage for when it works it works very well
Thanks
Old 06-13-2007, 12:51 PM
Big Sky's Avatar
Big Sky
Big Sky is offline
I am having the same probelm and replaces the switch as well...probably will take it in to be repaired soon...
Old 06-13-2007, 01:33 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
sound like clutch air gap
Old 06-18-2007, 08:38 PM
bridgeendfarm
you are right ty it is the air gap it seems, I am removing the clutch and reshimming it tomorrow. It appears to be a common problem as they get older. Thank you again very much
Old 06-18-2007, 08:45 PM
rbaker6336's Avatar
rbaker6336
don't know why they aren't shimmed a little closer new have had to do some before 20k miles but is normally fairly easy
Old 06-18-2007, 09:53 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
If you need a how-to, see my Post #10 here:
https://www.ford-trucks.com/forums/5...king-well.html
Pop
heebeha
06-26-2015 11:17 AM
outdoorfan
10-11-2013 05:48 PM
Schuyles
22
06-14-2012 07:54 AM
Frankiels3
1997-2006 Expedition & Navigator
12-12-2011 04:20 PM
Quick Reply: 2001 Ford F250 Suoer &.3 Diesel Air Conditioning Problems
