f250 vs f 350
f250 vs f 350
I really dont have time right now to check this out on the ford web site. Thought I would ask this real quick here on the forum. With all else being as equal as possible what would be the major differences in the single rear wheel f250 vs the f 350 6.4 diesel.thanks in advance.
Assuming you're talking about a CrewCab 4x2, the tow ratings are the same (15,700 fifthwheel), so you're just looking at payload capacity. The 350 will hold about 1100 lbs. more.
F-250 CC SB 4x2: 2670-3030 lbs. payload
F-350 CC SB 4x2: 3740-4090 lbs. payload
There is a difference in ride quality, but not really that much. Other than that options are the same to my knowledge.
The 08' have longer rear leaf springs, the ride quality has been greatly improved over previous years. If I'm correct the 04's still had leaf springs in the front. The new coil-overs make a very big difference.
The rear ends are just slightly stiffer the higher you go in weight rating. But the way they are biulding them now it's still hard to tell. The 08' F-450's ride smoother than the older F-250's, just goes to show you Ford is working hard to giver you a heavy duty truck that you can still drive all day long.
Originally Posted by PHWLEE
That and the badging are about it. I believe the F350 has the 2 inch blocks in the rear.
All the 350 and 250 rear axles I have seen have the same spline count and carrier.
Is that all there is to it? Lift blocks?
I heard this years ago but only when I started working on the axles did I realize its the same stuff.
Here are the axle specs...
www.fleet.ford.com/truckBBAS/non-html/2007/vs_pdf/fseriessd_07bb.pdf
Pages 16,17, and 24
www.fleet.ford.com/truckBBAS/topics/2008/specs.pdf
Pages 18,19, and 26
Axle Shaft
F250
— Spline Minor Dia.(in.) 1.36"
— Spline Major Dia.(in.) 1.50"
— No. of Splines (Hub End) 35
Capacity (Rating @ Ground) 6200 lbs.
F350srw
— Spline Minor Dia.(in.) 1.50"
— Spline Major Dia.(in.) 1.57"
— No. of Splines (Hub End) 37
Capacity (Rating @ Ground) 7280 lbs.
As far as I know model years 1999 to 2004 the rear axles were the same.
Pages 16,17, and 24
Pages 18,19, and 26
Axle Shaft
F250
F350srw
oldblue18
03-09-2001 08:15 AM
