Turbo Injection Pump
Old 06-16-2007, 12:45 AM
swhess1227's Avatar
swhess1227
swhess1227 is offline
Question Turbo Injection Pump
does the injection pump and injectors dump more fuel than the non turbo injection pump and injectors and can you put the turbo pump and injection on a non turbo 7.3 with out any problem???
Old 06-16-2007, 08:47 AM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
There are numerous differnces between injectors and IPs which match the different engine(s). You could use any IP and injectors but over/under fueling, incorrect timing etc could/would/may be a problem.
This is info I have saved for a few years......a friend wrote and asked....Stanadyne.
Ok hear we go. I got in touch with Stanadyne Corp. and asked about our injectors, a topic that turns up often! Hear is the scoop.
"Although this is really a question for Navistar, I will provide you with some information.
There are three different injectors used in 6.9 & 7.3L engines - one for the 1984-1992 6.9's & 7.3's, one for the 1992 1/2 - 1994 engines that Navisatar referred to as the "P&E" (performance & emissions) engines and one for the 1994 turbocharged engines.
In reviewing the drawings I see that in addition to to different nozzle opening pressure for the injectors, there are a number of differences between the nozzles including:
different pintle diameters, pintle bore clearance, valve overlap length,valve extension etc. all which result in different valve lift vs flow characteristics and therefore result in the different injectors for the different engine applications."
Sincerely,
Mark Dionne
Manager, Product Support
Stanadyne Corporation
Your 92.5 engine** in your 93 if not a Factory Turbo......should use: E injectors and 5013 IP
** (Check tag on timing cover/oil filler housing)
Realslowww
13
05-29-2015 11:51 PM
fedx95
Ford Truck Parts for Sale
02-17-2015 07:08 PM
bill11012
06-02-2010 01:31 AM
DiscountPowerPrt
Vendor Specials, Discounts, Product Announcements & Group Buys
12-07-2007 10:27 PM
TexsDixieDiesel
03-07-2005 09:34 PM
Quick Reply: Turbo Injection Pump
