A/C hissing
A/C hissing
I have a 2006 screw with the 5.4 and I get a hissing type noise from the A/C. It cycles every 7 seconds and sounds like it's coming from the far passenger vent area. It sounds like it's recharging itself or something. I've taken it into the dealer and the first time they said it was the vacuum driven system then the second time they said it was the freon recharging itself. Is every 7 seconds a little to often? It seems to get louder the longer I drive. Needless to say after a four hour trip to the beach hearing this hissing every 7 seconds drives me crazy. It will hiss then stop for seven seconds then hiss again. Anyone??? Thanks.
This may not be the case, but I had the same problem with hissing a few months back. Every time I turned on the fan, the hissing got louder. I looked and looked and almost tore apart my dash. Then, I noticed the sound was coming from a bottled coke I had in the cup holder in front of the vent. Yes, I felt dumb. The noise was from a partially opened and partially shaken coke bottle. This probably is not your problem, but I thought it was worth mentioning.
If you have the EATC then yes it is normal, the computer will control the ac and do a bunch of different thing to control the ac, one thing is to put in on 60 degrees and press the vent button with the max ac/recirculate button, this eliminates the AUTO function, which is the computer controlled function
My 2006 FX4 does it too, i have the auto climate control thingy too, i only notice when the radio is off though, and that is not very often so it doesn't really bother me too much!
