You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So does anyone here make thier own fuel?? I've seen the shows where people make it from used cooking oil, does it work? is it worth the time? and do you have to do anything to your truck before using it?
Just wondering, seems that it would be a good way to save a little $$!!! the process seems pretty simple and not alot of up front investment.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Welcome to FTE! And welcome to our biodiesel forum.
The answer to your question is YES! There are a bunch of us here making and using biodiesel. I myself have been making it for almost 4 years now, and I still smile everytime I pass a fuel station............
Also check out the posts in this forum, there is a lot of experance here, and we're all willing to help you on your way to making your own fuel.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Yes we do. I run my truck on WVO (waste vegetable oil) Fabman is one of the leaders of the Biodiesel on this forum. If you want to run WVO you need to convert your Diesel engine to run on it. Its best to have a two tank system. One tank for the WVO and one for Diesel. I start on Diesel and when the engine is up to operating temp I switch to WVO. Before I stop I switch back to Diesel. If you have any questions just ask and someone will have a good answer.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
So what will it take $$ wise to realistically get going with this?? I have a free source for veg oil, my brother owns a restaurant and says its all mine if I want it. Also he uses canola oil mostly due to all of the hub-bub over trans-fats, will that make a difference?
What is the breakdown? as in how many gallons of cooking oil makes how amny gallons of fuel??
Do most of you guys run two tanks like willbd? How and who or where could I get another tank installed? sounds like to big a job for me!!
And I guess what I really need to know is if it's worth all of the time and effort?? I have people telling me thats its not worth it and it messes up your engine and voids any warrenty.
If you want to run BioDiesel the start up cost is relatively low, $200 to $300 will get you going, but there is an ongoing production cost, about $1 per gal.
If you chose to run straight WVO the start up cost is high, as much as $3000 to convert a truck, and the ongoing cost is very low a little electricity and some filter elements from time to time.
You will find those that advocate blends, mixtures of WVO and various other liquid hydrocarbons. If you chose this method realize it is an absolute crap shoot you are gambling the life of your engine to save a few bucks. I for one will not take that gamble. They will tell you about friends they know that have run a mix of WVO and whatever for eons and have had no problem. That is anecdotal evidence not good scientific evidence and scienctific facts do not support their theories. I have a 4 year post grad degree with a minor in biochemistry. I will not run blends in my truck.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Phy,
Are you saying you wouldn't run the homemade Bio in your rig because of the mixes? Or are you saying you wouldn't run WVO?
Just trying to feel out your thoughts on which is better.....I'm looking for a IDI now to tinker with.
Knowing Phydeaux from his past responses, I'd say he's saying he will not run a blend because wvo and #2 are different specific gravities. What that means is that given enough time, they will separate, and eventually, your truck will be running on almost 100% wvo- which can hurt on start-ups, cold wvo will coke up your injectors and such, causing problems. I have mixed #2 and wvo in a small jar and it sat for three days before I dumped it in my tank, and it never showed a sign of separating. I myself will still go by what the experts say- either run a truck converted for wvo, or run bio, but no blends. But to each his own, ya know?
__________________ Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
Mongo pretty much got it right. I dont trust blends of WVO and any other fuel.
I will run BD/#2 blends in any concentration because they are totally miscible (specific gravity, molecular weigh, molecular size, and molecular polarity very similar)
I agree completely with the concept of convert the truck and run straight WVO or run Bio.
BTW I hear the IDI engines are much more forgiving than DI like the Powerstroke.
__________________
That is a funny and interesting way to go about that. Run a start/stop biodiesel tank and wvo tank and switch..ha ha ha the oil companies would be ping mad at that. Homemade bio a buck, wvo for running priceless (junk). Talk about reducing your cost even more. Our sponser here should get a chuckle from that idea. Good one Bigguns.
__________________
585,000+ miles on original engine. Goldie 00 F-350
Hell, with the two tanks you have in the early diesels, that's exactly what I'd be doing!
