Dome light wont shut off!!!!!
I am still working some kinks out of my B2 and tonight the dome light decided it does not want to shut off. I have checked all the doors and hatch to make sure they are closed tight. And I have checked all the plungers. I puleed the fuze for now but I was wondering if anyone has ever had this problem and where do I start? Thanks in advance.
on
1 Post
rebo, the older BIIs and Rangers didn't have a switch on the lamp assembly itself, if that is where you were going with your suggestion. I have a feeling that one of the door switches (more than likely it's the driver's side or the liftgate) is bad or there is a short somewhere in the wiring.
Check the rear plunger on the hatch..mine used to come on and that's where the problem was. Even though the hatch was closed the switch wasn't working properly. I just took out the switch. The light still works when the drivers and passenger door are opened. The rear cargo light also has it's own button on it to turn it off/on with the rear hatch opened.
Thanks for the info guys. I'll work on it some more tommorow. Somethings gotta be going on with it though, I went back out and messed around with it some tonight. Now my radio doesn't have power. It is an after market CD player but I bought the harness kit for it. I dont like hacking into factory wiring. As far as a short in the wiring I definately need to look into that more. Last week I turned the defrosters on and the blower motor made a heck of a racket, then poof smoke through the vents. I pulled the motor off to find a mangled mouse in the heater box, and enough corn to plant half an acre. I'll have to see if I still have a wiring diagram for B2's and go from there.
on
1 Post
Yeah, actually, as Jeff mentioned, the liftgate switch tends to get messed up, or the retainer breaks off, so it sends the signal to the circuit to turn the lights on and they stay on. I forgot about that (uh, DUH, that's why mine was removed by the previous owner!). Sounds like you may have a blown fuse on your radio and that you'll need a new blower motor for the a/c - heat. Gotta love daily drivers that turn into projects! Hope you get 'er all fixed up soon.
