Go Back   Ford Truck Enthusiasts Forums > General > General NON-Automotive Conversation
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-02-2007, 07:52 PM
XXL Supreme XXL Supreme is offline
Garage is empty, add now
XXL Supreme is starting off with a positive reputation.
Digital Coaxial vs. Subwoofer RCA cable
I just purchased a powered subwoofer for my home stereo. It was used and I didn't pay much. I tried running a digital coaxial cable from my digital Pioneer receiver (subwoofer preamp out) to the subwoofer itself but can't get any sound out of it.
Then I tried the usual double-tipped rca cables, just plugging in one side of each cable end.....that did not work either.
Do I need to get the actual subwoofer rca cable? Or should the digital coaxial do the job and my problem is not due to the cable?
Thanks!!
__________________
1985 F150 351 H.O. 4x4
1986 Crown Victoria (H.O. converted)
  #2 (permalink)
Old 06-02-2007, 07:56 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
The cable shouldn't matter, but you may have a bad cable or two. Or maybe your receiver isn't set to output the sub signal.
Coaxial and RCA cables are essentially the same--shielded cable but with different terminations. Calling them "digital" is just a marketing ploy.
Jason
__________________
-2003 E250 cargo 4.2L V6, 4sp electronic auto, 22 axle (work van)
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
Probably the greatest harm done by vast wealth is the harm that we of moderate means do ourselves when we let the vices of envy and hatred enter deep into our own natures.
Theodore Roosevelt
  #3 (permalink)
Old 06-02-2007, 08:13 PM
I know my coaxial cable is good because that is what I usually use between my dvd player and receiver. I just switched them back and forth to see if what worked for the dvd player would also work for the subwoofer.
I looked up some info on the subwoofer I just purchased....it is the type of subwoofer that powers a small home entertainment type system.
I already have all the speakers I need powered by the Pioneer receiver and don't need the subwoofer to do anything but woof.
Also, my receiver has three choices for the subwoofer: subwoofer on; subwoofer plus (extra bass) and subwoofer off. I have it in the "on" position lol!!
Thanks for your response! It is very much appreciated!
__________________
  #4 (permalink)
Old 06-02-2007, 09:13 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Giving us part numbers for your stuff will help.
Does the sub have a switch to choose input type (RCA or Speaker Input)?
What is the crossover set at?
  #5 (permalink)
Old 06-02-2007, 10:26 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
I curious to see if you put it on the correct pre-out on your reciever. If so then you might have to go into your amp + dvd menu's on change some settings so the sub works. I have a Pioneer amp also so I might be able to help you out.
  #6 (permalink)
Old 06-03-2007, 12:17 AM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
2007 Ford Expedition
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
Quote:
Jason
this article states Rca's are not sheilded
http://www.samspublishing.com/articl...&seqNum=2&rl=1
  #7 (permalink)
Old 06-03-2007, 12:34 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
Most older rca cables weren't shielded, almost all the new ones are.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #8 (permalink)
Old 06-03-2007, 07:58 AM
Yeah, I wasn't thinking of the older RCA cables...I was talking about cable-style coax and RCA-style coax. Same cable, different terminations, as the linked article basically stated. I guess when I hear "RCA", I think of the termination, not the cable itself.
Jason
__________________
Theodore Roosevelt
  #9 (permalink)
Old 06-03-2007, 12:43 PM
Quote:
The Pioneer has two subwoofer outs. One is a subwoofer pre and the other one is part of the 5.1 outputs, which I don't use. I use my system for audio only, no movies.
According the the Pioneer manual, the only assignments I can do with the subwoofer is to turn it on, off, or subwoofer plus. If there are any other settings to change regarding the subwoofer, I can't find them in the manual.
Here is some model information:
Pioneer Multi-Channel Receiver VSX-D409
Powered Subwoofer:
Emerson Research
Cinema Surround
Model #: Micro 10
Model System: SP10W
90 Watts
Thanks for all your help guys!
__________________
  #10 (permalink)
Old 06-03-2007, 12:45 PM
The sub does not have a switch to choose input type.
There are no crossover settings on the sub either.
__________________
  #11 (permalink)
Old 06-03-2007, 01:19 PM
First, RCA Cables and Subwoofer cables are the same thing. It is mainly just marketing to sell a subwoofer cable, although it does allow you to buy one cable rather than the two you normally get when purchasing RCA audio cables. Digital Coax Audio cables are slightly different but I can't remember what it is about them that is different (they do have RCA type ends on them as opposed to what most people call coax cable which is RG6 cable). If you have another set of RCA cables try them and see if they make a difference.
Second, some recievers only put sound out of the subwoofer pre-out when there is a specific subwoofer channel, like in 5.1 DVDs. You need to hook up a DVD player and verify if this may be your problem.
Finally, you do realize that this unit isn't going to put out very much or very clean sound right. It is only a 20watt 6.5" woofer.
  #12 (permalink)
Old 06-03-2007, 01:41 PM
rywegh's Avatar
rywegh rywegh is offline
rywegh has a good reputation on FTE.rywegh has a good reputation on FTE.
Ryan M Weghorn
ummm, maybe a stupid question; but here it goes anyway...... you say you bought it used. Are you sure the sub actually works? Did you hear it play before buying it?
__________________
Ryan > Kentucky chapter member
Saying a person carrying a gun is out looking for trouble is like saying that by wearing a seat belt you are looking to get into a violent accident...
  #13 (permalink)
Old 06-03-2007, 04:26 PM
Quote:
Not a stupid question at all! The seller of the sub said it powered up, but he had no way of testing it. I can return it and get my money back if it doesn't work. So to answer your question, I do not know if it actually works. I do know it powers up.
I run a dvd player through my system exclusively. I use it to play regular audio cds. Therefore, I don't use the 5.1 subwoofer out on my receiver. The receiver has another subwoofer pre out to use when not using the 5.1 out.
I'll throw a 5.1 dvd in the player; hook the sub to the 5.1 sub out; make the needed adjustments on the receiver so it knows to recognize everything 5.1, and see if that works!
I realize I am not going to get killer bass out of this thing. I am simply on a mission to figure this thing out!!
__________________
  #14 (permalink)
Old 06-03-2007, 04:40 PM
I realize that you have two subwoofer outs, and I assume you are using the one right next to the speaker jacks and not the one that is part of the 5.1 analog outs. Like I said though, some recievers only output to the subwoofer output (the one by the speaker jacks) when there is a specific subwoofer signal. I'm not sure about your reciever.
I just thought of another thing. What are you plugging the subwoofer cable into on the sub? Does it actually have a subwoofer input, or does it just have the standard left and right RCA inputs?
  #15 (permalink)
Old 06-03-2007, 04:43 PM
It has standard right and left rca inputs. One of which is labeled "mono".
__________________
Tags
cable, cinema, coax, coaxial, cox, differences, digital, emerson, micro10, rca, research, run, subwoofer, surround, thing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
