5.3 chevy in 79 shortbed 2wd
Old 06-04-2007, 07:33 PM
Dustin1690's Avatar
Dustin1690
Dustin1690 is offline
Why why why no seriously why what for chevy engines in a ford i really hate that truly makes me mad and sick!!.. like i see enough chevy engines in the 50s ford trucks
like you have tons of choices whether it be efi or carb 300 I6, 302, 351M or W 400, 460, 390, 360, V8s even can swap in a 429 or 428
Old 06-04-2007, 08:17 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
Unhappy
For no reason in the world should this be done.
It is a new model engine and would be very difficult to do in the first place, but I have seen someone put a 5.4L for a 04 F150 into a 78 Bronco and that thing was nice. He even put the 04 dash and seats in it also.... Very nice!
But chevy in Ford.....
Old 06-04-2007, 08:20 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Some people love the Ford styling but also love the cheapness of fixing a GM engine
Old 06-05-2007, 01:00 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
FordTrucksKickGM is offline
BAD IDEA!
If you are that desperate for a good Ford engine Im sure we can all pitch in and find something decent for you.
Wow, I am weeping for your truck!
Old 06-05-2007, 01:26 AM
AZ_Catskinner's Avatar
AZ_Catskinner
AZ_Catskinner is offline
I'm in no way on board with the Chevy idea (yes, I own one too), but if you're looking for something to make a hot rod, I'll share with you an idea I've been toying with for a while.......
Why not a Lightning/GT40 351W? Add a modest lowering kit, Addco swaybars, a set of 17x8's and appropriate rubber, and make a vintage Lightning? Maybe even the T-Bird SC seats and decals too?
There's a 79 2WD for sale up the road here, and if only I had the money............
Old 06-05-2007, 07:56 AM
acc2828's Avatar
acc2828
acc2828 is offline
FRANKTRUCK wouldn't even do this. If you continue this thought proccess you run the risk of having all the country western songs start singing about thier dogs and wifes and girl friend coming back home. But the trucks will start to die. DON'T Do IT !!!!!
Old 06-05-2007, 01:13 PM
Louisianaforddriver's Avatar
Louisianaforddriver
Louisianaforddriver is offline
This idea is just wrong !!!!! For the love of god dont do it!!!!! PLEASE, swap in a 351 modified, or a 400. Anything but a chevy.
Old 06-05-2007, 02:57 PM
bomberboat's Avatar
bomberboat
bomberboat is offline
hell it's your truck do what you want to do. it would be a boring world if every thing looked the same ran the same.sounded the same. and everyone would think the same.ahh **** off some people, do it. hahaha
Old 06-05-2007, 04:58 PM
flcracker9's Avatar
flcracker9
flcracker9 is offline
Chevy in a Ford = BORING!!!!!!!!Don't screw up the classic Fords by installing a BORING engine under the hood. If you've seen one small block/big block Chevy, trust me you've seen them all. It doesn't matter what modifications are done to them, they all Look the same - BORING. Just my opinion!. Did I mention that Chevy engines are BORING?, well they are!
Old 06-05-2007, 05:18 PM
dwrestle's Avatar
dwrestle
dwrestle is offline
It's your truck dude, but I wouldn't even replace a BOP engine with a Chevy engine. If I were you I would put the same motor it came in there stock, unless it was a 300 and you have to have a V8. If thats the case at least put a 351 in it, don't bother with the 302 unless it's cheap and it's got GT-40 heads from an Explorer, I know someone who swapped one in a 73 F-100 that had a dead 360 to begin with, and that truck will fly now, but probably not as good as the 360 when it was fresh. If it had a 300 the Windsor and 351C Engines will fit the bolt pattern of the tranny, if it has a big block bolt pattern put whatever you can find in it, 351M, 400, 429, 460, and I don't know if the FE engines have the same bolt pattern as the 385 and 351M and 400 engines or not. If it has a 300 and you don't need the V8 sound, heat that 300 up it won't dissapoint, and it will last forever.
Old 06-05-2007, 11:11 PM
timothy47129's Avatar
timothy47129
timothy47129 is offline
chevy performance parts are easier to find and alot cheaper.
Tim
Old 06-05-2007, 11:28 PM
FE Man's Avatar
FE Man
FE Man is offline
You must be out of your tree monkey. Why in the world would you post this on this forum? Take your ideas and go somewhere else. Grow a pair and put a ford motor in it, way easier and alot less headache trust me. Hope you smarten up.
  #28
Old 06-05-2007, 11:33 PM
StarTrash's Avatar
StarTrash
StarTrash is offline
im only 17 and have owned 3 ford trucks..and i say Screw That hell i have 390 fe from a 74 f100 2wd here in my garage i would sell you VERY cheap just to keep you from putting a damn chebby in a FORD 79...
  #29
Old 06-05-2007, 11:40 PM
75F350's Avatar
75F350
75F350 is offline
That is an LS(X) engine with aluminum Vortec heads. It has a bit of a limitation with the small bore size, but is making 1hp per CI, and is capable of more, (a lot more) and is a hot engine right out of the box. The 4L60E is a strong unit too. That is actually a very potent combo, and not too hard to wire, or install. I run them in rock buggies.
We have guys wondering whether or not to send early Ford trucks to the scrap heap or not, and nobody complains about that . But everyone has a heart attack because someone wants to install a bow tie in one. Hey, at least the guy is keeping it on the road, and not sending it to the crusher.
Even life with a bow tie powerplant is better than sitting around with no engine at all, with weeds and stuff growing up through them, or chickens living in them.
How many of those have we seen?
We also have guys instaling Cummins engines in these trucks, and they get a pat on the back.
I say, as long as it is on the road, and not parked, cool, so let individuals be individuals, and don't get so bothered if someone dares to do something different. They are not asking you to do it, just want to do it themselves, thats all.
  #30
Old 06-05-2007, 11:50 PM
StarTrash's Avatar
StarTrash
ok i do agree with 75 350 on that one..
Quick Reply: 5.3 chevy in 79 shortbed 2wd
