twEECers?????
twEECers?????
I went to www.fordfuelinjection.com and they have a link for something called a tweecer (tweaker).....I have a 95 flareside and I can't find a flash tuner or a comp for my truck...all I can find is a JET chip......but this tweecer installs into the back of your EEC and let's you hook it up to your laptop (like the ricers) to adjust your fuel,timing,spark, and shift points...sounds pretty cool fer only 380 bucks, but has anyone used it?What are your opinions?Thanks.....
tweecer
I currently use the Tweecer on my taurus sho's. If I may suggest get the Tweecer RT model. It allows live data logging. The changes your able to make to your eec is extensive. Mike
http://www.tweecer.com/
I tried to use it once, but I couldn't find BINs for my applications.
Another option would be sniper's delta forces, they cover back to the mid 80's. http://www.snipertuning.com
BTT
I'm looking at the TwEECer unit and would like to know what kind of peculiarities it has, limitations, and general price : performance ratio. I'm going to do some pretty heavy cylinder head modifications and will need to re-tune to get the most out of my engine. Anyone want to give the down-and dirty details?
Edit: At $550 + S&H, nevermind.
if you're willing to do some research and spend some time learning you should check out www.moates.net
Jim
Jim
what year truck was that on?because lately I've been hearing of custom tuned chips by superships and diablo......but they say they don't do anything for my year......I'm gettin ready to pull the 5.0 outta my parts truck and rebuild it with some light performance mods.....flat top pistons all new bearing and rings possibly a milder cam from stock as well as port matchin the upper and lower intakes,TB,and headers.Getting ported heads with dual vassco springs and roller rockers then longtube headers goin from 2 into 1 3 inch pipe with probably a Dynomax bullet racing muffler(quiet at idle loud at throttle) Once I'm done with all that, then I'll where I'm goin from there.....
