Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-26-2007, 11:24 PM
John with beastly 302 John with beastly 302 is offline
John with beastly 302 is starting off with a positive reputation.
Question How To Control TCC Lock Up
I own a 1991 F-250 with the fuel efficent 460. I am getting the truck repainted at maaco $4000. I will be linexing the bed and hand brushing the frame. I love the truck except for the early torque convertor lockup in second gear. Is there any way I can manually control the TCC lockup with a switch?
__________________
2005 F-350 XLT 4X4 Dually 6.0 Auto (Parents)
1991 HD F-250 XLT Lariat
Fire Breathing 460 V-8 E-4OD
RIP 94' F-150 4X2 5.0 MAF 4R70W Super Cab Shorty Green W/ tan accent 2" front lift Flowmaster 40 3-20-94 to 6-8-05 First truck and I hit a bridge reaching for the cellular
  #2 (permalink)
Old 05-27-2007, 07:34 AM
subford's Avatar
subford subford is online now
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Yes you can, I have a box that will even change gears.
I take it you have an E4OD so you would cut the circuit #480, a Pink wire with a Yellow stripe.
Tape back the end going to the PCM.
Take the end going to the Transmission and run it to a switch and the other terminal of the switch needs to go to a good ground.
With switch off the clutch is off and when the switch is on the clutch is on.
The above decryption was for a 1992, yours should be the same.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #3 (permalink)
Old 05-27-2007, 07:49 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
He could also put the switch inline to produce:
OFF- Clutch is off
ON- Clutch operates normally
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #4 (permalink)
Old 05-27-2007, 08:59 AM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
or use a 3 position switch and have on off and auto.
__________________
Ford F150 2X4 standard cab short bed 4.9 300 cid 5 speed with 8.8 2.73 100% original this is my Baby
93 Explorer 4X4 with 4.0 Auto 100 % stock
2003 Ranger 3.0 auto.
I live and work in southern Baja Ca. Mexico.
Bruce
  #5 (permalink)
Old 05-27-2007, 01:09 PM
subford's Avatar
Quote:
That is the way I have it in my box.
__________________
subford@gmail.com
  #6 (permalink)
Old 06-05-2007, 12:43 AM
Were do I find this Pink wire with a yellow tracer at? I will probably just have a switch inline to make it easy. Is there any concern in leaving the torque convertor Disengaged, are there any guidelines? I think I will install a Temp gauge in the outlet cooler line to get the hotest fluid temp out of the TQ.
__________________
  #7 (permalink)
Old 06-05-2007, 08:30 AM
subford's Avatar
Quote:
I am not sure on a 1991 but if it is like a 1992 the posted diagram below will show you. C103 should be on the driver's fender.
No, the clutch is to give you more MPG, with out it, it will act like a TQ without a clutch.
__________________
subford@gmail.com
  #8 (permalink)
Old 06-05-2007, 08:12 PM
351slug's Avatar
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
That sounds like nice performance trick. I guess I need to buy a manual to find these wires. Can you do all the wiring under the hood ? I have a 93, will it be the same ?
  #9 (permalink)
Old 06-05-2007, 08:32 PM
subford's Avatar
Quote:
I do not know what you mean by performance trick, this will cost you MPG and give you no more power.
Yes you can and no place else.
Yes it will if you have a E4OD.
It main use is to turn off the clutch while troubleshooting shudder in the Transmission.
__________________
subford@gmail.com
  #10 (permalink)
Old 06-06-2007, 12:23 AM
Cool Thanks for the reply. I wonder were the Transmission tempature sensor is located at, and if it would be possible to tap into it for a temp gauge?
__________________
  #11 (permalink)
Old 06-06-2007, 11:58 AM
subford's Avatar
If you use a hi-impedance 0-5 Volt DC meter I would think you could tap into it, if you do let us know how it works out.
Transmission Fluid Temperature (TFT) Sensor 7H141:
The transmission fluid temperature (TFT) sensor is located on the main control valve body (7A100) in the transmission sump. It is a temperature sensitive device called a thermistor. It sends a voltage signal to the powertrain control module. The voltage signal varies with transmission fluid temperature. The powertrain control module uses this voltage signal to determine whether a cold start shift schedule is necessary. The shift schedule is compensated when the transmission fluid temperature is cold. The powertrain control module also inhibits torque converter clutch operation at low transmission fluid temperatures and corrects EPC pressures for temperature.
The Transmission Fluid Temperature (TFT) sensor is a thermistor that changes resistance in response to temperature. The TFT sensor resistance decreases as the surrounding fluid temperature increases. The resistance variation is converted into a voltage signal and sent to the PCM to give an indication of the transmission fluid temperature.
Note: Voltage values are calculated for VREF = 5.0 volts: These values may vary 15 percent due to sensor and VREF variations. Transmission fluid temperature must be minimum of 10°C (50°F) before taking transmission fluid temperature sensor resistance measurements.
Good Luck
__________________
subford@gmail.com
  #12 (permalink)
Old 06-07-2007, 06:29 PM
351slug's Avatar
Will having the c103 coming from trans grounded for a long time hurt it ?
  #13 (permalink)
Old 06-07-2007, 07:02 PM
subford's Avatar
C103 is a connector, how are you going to ground it?
If you mean circuit #480 the engine will die when you come to a stop. It would be like trying to drive a standard (stick) shift without ever pushing in on the clutch.
__________________
subford@gmail.com
  #14 (permalink)
Old 06-07-2007, 07:07 PM
351slug's Avatar
Sorry, I was confused. I thought I was reading it would keep the Tourqe Converter from locking up. Thats what I would want it to do till atleast 55 mph intead of 35 mph.
  #15 (permalink)
Old 06-07-2007, 07:20 PM
subford's Avatar
You would need to open (break) the wire or put it on a switch that would open (break) it then. That way the computer could not ground it to make the clutch come on.
__________________
subford@gmail.com
Tags
150 , 60 , converter , diesel , e350 , e4od , ford , installation , lock , lockup , switch , tcc , tft , tourqe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
