Just bought Grandfather's 1951 F7
Old 07-29-2007, 06:48 AM
joes52f6's Avatar
joes52f6
joes52f6 is offline
Fomoko1 is right do NOT use retreads on the front. They will blow out or fall apart easily on the front, and on a sweet truck like that I wouldn't take the chance.
  #32
Old 07-29-2007, 09:50 AM
Chicago Fire Patrol's Avatar
Chicago Fire Patrol
Chicago Fire Patrol is offline
Thanks guys ... Good advice!!!
Keith
  #33
Old 07-29-2007, 10:55 AM
Blue50F-1's Avatar
Blue50F-1
Blue50F-1 is offline
I have no personal experience with retreads, but I've always heard the general rule of thumb that the worst tires go up front on a rear wheel drive because if a front tire blows out you can steer to correct it. If a rear tire blows you find yourself spinning circles and that I have seen first hand. Saw a guy in a small rear wheel drive car have a blow out on the right rear and nearly lose his life in the resulting wreck. Is there some bonafide reason this safety rule of thumb shouldn't be followed with retreads?
  #34
Old 07-29-2007, 11:33 AM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
This isn't a small car.....You never want to put retreads on the "steers" on B I G truck. ......Well maybe not NEVER..... I put Brand NEW TOYO 9.00-20 radial tube type tires on the front of my 55 F-600 and capps on the duals.
I would not put recaps on the front of anything I own. I would say that prohibiting recaps on busses and farm labor vehicles is a safety issue.....good enough for me!
Here's what California says. http://www.green.ca.gov/EPP/vehicles/RetreadedTires.htm excerpted below...
Tire Condition and Use
California Code of Regulations (CCR), Title 13, section 1087
(c) Recapped Tires. Tires recapped or retreaded for highway use shall have a tread pattern that complies with Section 27465 of the Vehicle Code and with this section.
Recapped or retreaded tires shall not be used on front wheels of a bus or farm labor vehicle.
Such tires shall not be used on the front wheels of truck tractors or motortrucks listed in Vehicle Code Section 34500 unless the tires are in compliance with the following requirements:
(1) Tires shall have been retreaded or recapped not more than two times and shall contain no casing repair other than that required by a nail puncture.
(2) Tires shall conform to either the labeling and other requirements of the 1972 CRSC [California Retreading Standards Committee] Retreading Specifications and Standards or to the Industry Standards For Tire Retreading & Repairing revised September 1, 1995. Tires retreaded on or after November 1, 1997, shall conform to the Industry Standards For Tire Retreading & Repairing revised September 1, 1995.
(3) A new-tire manufacturer who is assigned an identification number by the U.S. Department of Transportation (DOT) may certify adherence to standards equal to or better than CRSC standards (only until November 1, 1997), or the Industry Standards For Retreading & Repairing revised September 1, 1995 for retreaded tires produced in his/her company-owned-and-operated retreading facilities. Such certification shall comply with marking or labeling requirements of CRSC (only until November 1, 1997), or the Industry Standards for Tire Retreading & Repairing revised September 1, 1995, except that the certification mark branded into the tire may be of original design. A certification mark of original design shall show the name or trademark and assigned DOT registration number of the manufacturer and designate which of his/her retreading facilities produced the tire.
(4) Successive Retreads. When a retreaded tire bearing the markings specified in preceding subsections is retreaded a second time, the prescribed label shall be cancelled by a diagonal line or other distinctive mark through the label.
/////snip/////
Cheers,
Rick
  #35
Old 07-29-2007, 11:42 AM
Chicago Fire Patrol
Thanks for the good advice guys!!!
  #36
Old 07-29-2007, 11:53 AM
joes52f6's Avatar
joes52f6
joes52f6 is offline
If your ever driving a bigger truck f-600 and up, and a steer tire blows DO NOT slam on your brakes you will definitely lose control. The thing to do is keep on the throttle and safely steer to the side while slowing down by gently backing off the throttle.
  #37
Old 01-25-2008, 08:24 PM
Chicago Fire Patrol
Update with pics
Hi Guys
Just a little update on the truck. I have added some new pics that show the progress. I know everybody like pics. The brake system was completely restored. New master cylinder, rebuilt booster and wheel cylinders, relined shoes and brake lines. Replacement one piece rims that were sand blasted, straightened, pits filled, sanded, primed and painted. New Cooper 9R 22.5 tires. After owning the truck since last May, I will finally will get to drive it for the first time.
  #38
Old 01-25-2008, 08:35 PM
joes52f6's Avatar
joes52f6
joes52f6 is offline
Truck looks great. Glad to see your gonna get to drive it around. Good luck and enjoy the drive.
  #39
Old 01-26-2008, 03:52 AM
55 f350's Avatar
55 f350
55 f350 is offline
what a truck !!!!!!! love that thing !!!!!! more pics !!!! you cannot legally use , by illinois and federal dot rules , a retread on a steer axle . they will eventually if under use , come apart and you can / could lose control from it . that would be a crying shame and we'd have to convene court on fte to pronounce you guilty of injuring that beautiful old truck . under light use , the retreads on back will last a good long while , just not the front . and the tire store that sold you front retreads would be in a hurtlocker if dot or the state knew it . for that fact i cant remember ever seeing a retread steer ....... now more pics !!!!!!!!
  #40
Old 01-26-2008, 04:16 PM
52 ford pick-up's Avatar
52 ford pick-up
52 ford pick-up is offline
Hey i just joined as well and the folks on this site are the
best ever.
  #41
Old 01-26-2008, 05:04 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,114 Likes on 820 Posts
looking good.
Where did you get the wheels?
  #42
Old 01-26-2008, 05:05 PM
joes52f6's Avatar
joes52f6
joes52f6 is offline
Same thing i was wondering Bob.
  #43
Old 01-26-2008, 05:52 PM
John - NNY's Avatar
John - NNY
John - NNY is offline
Those are some great looking trucks.
  #44
Old 01-26-2008, 08:02 PM
Chicago Fire Patrol
Hi Guys
I got the wheels from chuck of chucks trucks. Expensive!!!
Keith
  #45
Old 01-27-2008, 12:27 AM
wmjoe1953's Avatar
wmjoe1953
wmjoe1953 is offline
She's looking good. Keep the pics coming. Want to see one of you and yours enjoying a quick stroll down the street (or the p-lot of the shop). Keep up the good work.
Quick Reply: Just bought Grandfather's 1951 F7
