plugs, yes or no
plugs, yes or no
i recently talked to the service guy at my local dealership about the plug situation. he said that he did that they had only done about two trucks that needed plugs out. he said for me to wait to replace mine. he also said that i could probably find out more info than him by reading the internet, which is why i went and asked them. My '05 scab has 31k, so should i or should i not?
NO...why risk breaking them early to prevent breaking them later?
It's just stupid IMO to take a potentially $4,000 or more risk.
when the truck is close to 100,000 miles, then change 'em. If they do break, you can either foot the bill to replace, or put a new engine in there for the same price. 2 birds with one stone the second way.
The $4,000 or so is because the heads are major PITA to remove while in the truck. It's easier to yank the engine.
they have. there is a anti-sieze that is used to prevent the electrode from catching. Unfortunately, the 04 and 05 guys didn't get the fix guick enough. Most 06+ should be just fine, but why take a chance?
Honestly though, how many trucks are still going strong at 100,000 miles without needing a rebuild? They may run well, but a rebuild wouldn't hurt things. Besides, the rest of the truck will show the mileage.
IMO, you're running on borrowed time once you get to 90-100k + miles. From my perspective, I don't understand your statement BigDaddy. I've bought a few vehicles with 100k+ miles and I had an engine standing by to slap in there. And usually a transmission.
all the one's i've owned except the dodge were/are going strong at 100K. hell i just bought an 88 with a 105K and it runs just as strong as ever. i dont' know where you get the point your running on "borrowed" time. who the hell would rebuild a motor before 250K? You do know thats when Ford and all the rest of them "RECOMMEND" (Depends on how well maintence and such was done) and i'm also glad you keep your engines on standby but since i'm leaving in a few months i won't need it as the truck willl be sitting for atleast the next 6 years probably less than 500 miles a year the rest of the time it will be on the concrete slab that we're currently building in the back yard. All these vehicles built today go past a 100K maybe in the past it was like that (dunno wasn't alive then ) but today thats expected hell my little 95 Escort went to 300 without any major trouble and especially without any rebuilds..
wow, you guys have had good luck. no matter what the brand, I've had my motors crap out with under 150,000. I've yet to make it past 100,000 without some major form of repair. that would be nice to make it that far.
and I'm a oil change and air filter ****. not to mention plugs/wires/cap/coil about every 12 months if needed or not. wonder if it's the way I drive.
I did have 94 F-150 with the 300 I-6 that got 127,000 before I sold it. The truck had the freeze seals pop out and ate spark plugs up, but otherwise never had an issue. The guy I sold it to drove it another 20,000 miles before the piston rings decided to go
Originally Posted by countryboy116
so just buy replacing the stock plugs and, for example, putting some motorcraft plugs in from the local parts store you can save $4 grand in the long run?
basically the argument is that if you change the plugs early on in engine life, you can avoid having your plugs break at the 100,000 recommended change. In theory, the early change will prevent carbon builup from accumulating.
IMO, you're risking a potential $4,000 spark plug change if you change the plugs early. The carbon build-up may have already happened enough that you'll break your plugs. You've essentially got a 50/50 chance of it going good/bad.
so why take that risk?
If they break the plugs they have a way of getting them out. There is a tool that they have that will take out the broken piece. I talked to my guy at the dealer and he said they havent had any problems taking them out. He knows there has been issues but nothing they couldnt get done even with one breaking. I would wait to have them replaced its just too early at 30k miles.
