Need Help!!! Exhaust Droan Vibration.
I HAVE A 2005 F-250 4X4 XL X-CAB 6.0L DIESEL TRUCK THAT JUST DEVELOPED A ANNOYING DROAN AT ABOUT 1500 RPM WHILE DRIVING. THE DROAN JUST STARTED YESTERDAY AND GOES AWAY AFTER YOU UP THE RPM PAST 1500 RPM AND COMES BACK ONCE YOU GET BACK TO 1500 RPM WHEN YOU SLOW DOWN. (IT ONLY DROANS AT 1500 RPM)
WHILE SITTING IN THE DRIVERS SEAT I CAN HEAR IT COMMING FROM IN FRONT OF THE FIREWALL BEHIND THE ENGINE YOU CAN HEAR IT BEST IF YOU SIT IN THE MIDDLE OF THE FRONT SEAT. FROM WHAT I HEAR IT SOUNDS AS BEST AS I CAN DESCRIBE IT A COFFEE CAN THAT SOMEONE IS VIBRATING WITH A SPEAKER UNDERNEATH OF IT WITH THE LID ON IT. I HOPE SOME ONE HERE CAN HELP ME AND KNOWS WHAT I AM TALKING ABOUT SINCE I MADE A APPOINTMENT FOR THE DEALER TOMMOROW AT 8:00 AM AND WOULD LIKE TO TELL THEM WHAT I AM TALKING ABOUT, THANKS GUYS FOR ANY HELP.
MY DEALER OF CHOICE IS: KENNY ROSS FORD
Route 30 @ Blackhill Rd, Adamsburg, PA 15611
akula22,
Please turn off the CAPS key as it is considered YELLING!
Here is the TSB on it
http://www.ford-trucks.com/tsb/fullt...p?tsb=05-19-12
Hope this helps
Hope this helps
Originally Posted by akula22
i have a 4in cat back mbrp t-409 stainless steel exhaust currently on the system with the muffler delete pipe installed also, this drone/moan only started reciently (8.16.07)
i installed my exhaust system last year and never had any problems until last week.
It's worth a try just to see..
Beachbumcook
09-24-2004 07:46 AM
