Nebraska Chapter Join Chapter, Leader: 97nukeford
460 and 351m bolt to same tranny?
Old 05-07-2007, 09:50 PM
tremaynr's Avatar
tremaynr
tremaynr is offline
I have a 1989 ford f250 with a 460 engine and a bad zf 5 speed tranny. I found a 5 speed zf tranny out of a 1990 f250 that had a 351m in it. Will this tranny bolt to the 460?
Thanks RT
Old 05-08-2007, 03:13 PM
cowboywanabe's Avatar
cowboywanabe
cowboywanabe is offline
Posting Legend
Hi RT, welcome to FTE! Somebody may post a reply here, but you might have better luck posting your question here: https://www.ford-trucks.com/forums/forum28/
Also, if you are a Nebraska guy, let us know and please join in on the chapter chit-chat.
Old 05-08-2007, 09:29 PM
fellro86's Avatar
fellro86
fellro86 is offline
And to answer your question, yes... The main difference is that the M tranny isn't as deep as the 460, but they will bolt and work.
Old 05-09-2007, 07:05 AM
tremaynr's Avatar
tremaynr
tremaynr is offline
Thanks fellro86, I appreciate the info.
RT
Old 05-09-2007, 09:20 PM
tremaynr's Avatar
tremaynr
tremaynr is offline
Thanks RT
I am a Nebraska man.
Old 05-09-2007, 09:30 PM
husker's Avatar
husker
husker is offline
I don't think the 351m was still used in 1990. That is probably a 351 windsor and that would have the 302/351 bell housing. That is smaller than the 351m/400/460. If you were using an auto tranny, the 351w tranny wouldn't work. Since you are looking at the ZF 5 speed the question is if it will bolt to the bell housing of a 460. You might ask the question in the tranny forum.
Old 05-09-2007, 09:46 PM
tremaynr's Avatar
tremaynr
tremaynr is offline
I may have typed this wrong the engine was a 5.8L out of a 1990 ford truck. I think it was a 351w.
Please help.
RT
Old 05-09-2007, 09:47 PM
fellro86's Avatar
fellro86
fellro86 is offline
I'm so used to people swapping engines around, didn't think to be sure that the 90 was actually the M or the W, Windsor. If it's injected, it would be a W, and no, the 460 will not work with it at all.
tremaynr's Avatar
tremaynr
tremaynr is offline
Ya you are right just noticed my mistake thanks
RT
thomtim4
New Member Introductions
09-10-2015 02:18 PM
shanes66charger
04-26-2014 08:42 AM
Tinterat
04-18-2014 03:25 PM
BruteFord
05-16-2013 10:04 AM
patsplace
05-23-2005 11:49 AM
Quick Reply: 460 and 351m bolt to same tranny?
