1978 - 1996 Big Bronco
4x4 problems 89bronco XLT
Old 03-10-2000, 11:08 AM
IMHIGH's Avatar
IMHIGH
IMHIGH is offline
Why does the 4x4 making a clanking noise when the truck is turning and it also feels tweaked out when it does move. Never used it before and bought it used so dont know the prior history.
Old 03-10-2000, 09:34 PM
Katt's Avatar
Katt
Katt is offline
Could be a U joint in one or both of the knuckles in the front axle.
Old 03-13-2000, 01:27 AM
Superdave's Avatar
Superdave
Superdave is offline
Yes it could be a u-joint bad, but keep in mind these vehicles turn quite sharp and you can get a lot if bind in the u-joints when you turn it sharply to either direction when in four wheel drive. You can check the front u-joints by grasping each piece of the axle and try to turn them in oppisite direction of each other. Watch for movement at the inside of the bearing caps. There is also a slip spline on the pass. side front axle by the differential that could be worn. As well check the front driveshaft out, u-joints and slip spline.
Old 03-13-2000, 01:22 PM
AlM's Avatar
AlM
AlM is offline
Did you put it in four wheel drive, high or low? and drive it on dry pavement? if you did..then it will be all over the place. Only use 4 wheel drive on sand, wet, or snow/ice conditions. Good luck and let us know how it turns out, AL M.
Old 03-15-2000, 07:28 PM
harv72's Avatar
harv72
harv72 is offline
Bat4x4
2017+ Super Duty
05-26-2016 09:12 AM
saltbranch
1999 to 2016 Super Duty
03-02-2016 09:00 PM
1972RedNeck
01-04-2016 05:57 PM
dmodracer3
16
03-02-2014 06:01 AM
clearnetedm
01-26-2009 07:08 PM
Quick Reply: 4x4 problems 89bronco XLT
