1978 - 1996 Big Bronco
Wheel size for 93 with 32x11.50
Old 04-17-2000, 05:55 PM
SWAT0701's Avatar
SWAT0701
SWAT0701 is offline
I am looking to put a set of BFGoodrich 32x11.50 on my 93. I have gotten different answers on what wheel size to use. I have heard 15x8 and 15x10. I do no four wheeling at all. Does anybody have 32's with 15x10 and are you getting a major rub on the radius arms. My Bronco has no lift at all. Thanks
Old 04-17-2000, 07:33 PM
AlM's Avatar
AlM
AlM is offline
yo!
I have a 96 Bronco and in DEC 99 I put on the same size..32x11.50's on 15 x 8" aluminum rims (Outlaw II by Amer Racing). All that rubbed was the driver's side air valence and bumper tip..The bumper is adjustable and we cut a slice off of the valence.
I bought Goodyear AT-S. For mostly beach driving and highway use. They have good tread wear and were $148.00 total since we bought the rims and tires from the same local tire shop. Much cheaper than any WWW site.
I did want to use black wheels in aluminum or HS steel, but chnaged my mind a few times and went for the lighter aluminum rims.
Good luck!
Al
Old 04-17-2000, 07:34 PM
AlM's Avatar
AlM
AlM is offline
I forgot to mention that I have no lift either.
Old 04-18-2000, 05:31 PM
JoeB's Avatar
JoeB
JoeB is offline
I have a 94 with 32x11.50 BFG AT's on stock Ford Aluminium Rims and I have only leveling coils on the front and add a leafs on the back and my tires don't rub at all. You can't go wrong with the BFG's they are excellent tires a little pricey but worth it.
Old 05-26-2000, 04:15 AM
duck's Avatar
duck
duck is offline
Old 05-28-2000, 06:55 PM
mauzer1's Avatar
mauzer1
mauzer1 is offline
I own a 95 bronco 3weeks ago I put bfg 32's on my truck I have stock alloy 15+8 rims no rubbing at all a friend has 15+10 after market rims he had a small rubbing problem then he added leveling springs to the front it went away. The tires look great.
Old 06-13-2000, 11:05 AM
bigmhoff's Avatar
bigmhoff
bigmhoff is offline
[font size="1" color="#FF0000"]LAST EDITED ON 13-Jun-00 AT 12:06 PM (EST)[/font][p]I had the same 32x11.5 dunlops on the stock 15x8 wheels before I put on the lift. It didnt rub, but it looked tight up front. Just didnt look right. Now, after the 4" lift, it looks too small! I need 33's!
1995 Bronco Eddie Bauer- 351ci- 4" Pro-Comp lift- 32" Dunlops- Front & rear Maniks- K&N FIPK- Dynomax 3" catback- Awia Head and changer.
el kamino
2015 - 2020 F150
19
05-14-2022 12:59 AM
351Cleveland C4
Offroad & 4x4
20
11-26-2019 06:25 PM
deano-was-his-name-o
02-22-2016 12:37 PM
NativeDescent
07-29-2015 09:52 PM
De-von Ford trucks
08-27-2012 11:32 PM
Quick Reply: Wheel size for 93 with 32x11.50
