1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 F250 CC how to remove door panels
Old 05-19-2007, 08:19 PM
Biggziff's Avatar
Biggziff
Biggziff is offline
Need to remove my front door panels to install different speakers and I'm wondering what the method is to remove them? On my 04 F150, they were really easy to pull off, just pop the screws and pull up and off...none of those annoying push clip thingies...so....anyone got the answer??
Thanks much..
Old 05-19-2007, 08:29 PM
Biggziff's Avatar
Biggziff
Biggziff is offline
Old 05-19-2007, 08:41 PM
PHWLEE's Avatar
PHWLEE
PHWLEE is offline
Those inside panels do not pull "straight off" After removing the hold down screws (one behind the reflector and the other behind the switch) you have to pull the interior panel UP about a half inch. If you pull it straight outwards, you will break off one or more of the plastic drop tabs. The plastic molding adjacent to the mirrors do pull straight out. Hope this helps.
Old 05-19-2007, 08:43 PM
Biggziff's Avatar
Biggziff
Biggziff is offline
helps a lot, thanks!
bigblue
05-12-2014 01:07 PM
Bladely
03-26-2012 03:53 PM
kris101966
2004 - 2008 F150
01-28-2008 07:08 PM
edgescreambeauty
03-02-2007 12:45 AM
mshostek
Paint & Bodywork
10-18-2006 08:26 AM
Quick Reply: 2005 F250 CC how to remove door panels
