Anyone running the Banks Ram Air Intake??
They are overpriced poor filtering crap like all the other A/M air intake systems for the 6.0. It will not increase your performance but it will increase the dirt ingested by your turbo and motor. It may also void your warranty.
Get your money back and spend it on something else.
The factory Donaldson air intake is the best intake and filter to use on the 6.0 and it flows more air than the 6.0 can use until you exceed 500+HP (this takes more than a tuner to achieve).
Originally Posted by ECA
I think BlackHat thought you were talking about the Cold Air intake, if you are talking about the Banks High Ram intake elbow. Just installed it. Check the new post.
http://bankspower.com/newproducts-2-06ra.cfm
Guess he will have to post back as to which one he was refering to.
thanks.
the donaldson is the oem filter system on youre truck ck some of the other posts by searching A/M intake you eill see why I replaced my afe stage II with the stock intake & filter, asit will flow sufficent for up to 500 hp & will hold 3lbs of dirt before replacement is nessecary it took me a while but I have been convinced that fords r&d budget on PSD filtration is probably more than banks, afe, volant, k&n, s&h & all others total line r&d combined! I am not willing to gamble my engine on a sales gimick! are you?
Originally Posted by Squatch
Do you have a link to the donaldson air intake??? I was just going to change mine out and took 10 minutes and SOB is still in the truck...so want to change it out to something that will flow better than stock.
thanks.
thanks.
http://www.donaldson.com/en/engine/s...ary/001220.pdf
As far as changing the factory filter there is a trick to it and it is explained in the Tech folder
http://home.austin.rr.com/sbv1/Proce...irFilterRR.htm
and a link with pictures
http://www.forddoctorsdts.com/articl...icle-06-01.php
BTW you only need to change the filter when the filter minder indicates it is time. And this can be up to 80K miles.
www.filterminder.com/
And the recent TSB as posted by BTH
http://www.ford-trucks.com/forums/61...-0-owners.html
So do yourself and your engine a favor and keep the factory Donaldson unit
Hope this helps
Thanks guys, I did a search on donaldson after I posted...what a dumba$$ I am..sorry...thanks for the info and links. No I am not going to gamble with my engine. I read on one of the posts that more flow means bigger holes in the filter so air can get through it...makes sense...I'm at 90k+ right now and don't know if PO changed it...I looked at it and seen that it was dirty..but the gauge doesn't say that it needs changed...so I am leaving it...
off to search about this zoodad thing...or what ever it is called.
thanks again guys.
thanks again guys.
sorry for any confussion guys...
ya, I was asking about the Banks new cold "ram" air intake.
I thought I remembered reading here several months ago about how the Banks intake that was comming out maybe the only good aftermarket unit.
I had $400 burning a hold in my pocket and just ordered it.
I was wondering if anyone else has taken the leap and just did it to try it out too.
Since the stock Donaldson filter can flow more air than the 6.0L can use until you get to 500+ Hp, what is the A/M filter going to gain you other than more dirt in the engine?
Since the engine is already receiving more air than it can use with the OEM Donaldson filter, you will see no performance gains with the A/M systems.
Not trying to pick on you but when we have guys that race the 6.0L with with an insane amount of Hp and over 950lb ft of torque state that through real world testing the OEM system is the best and you will see no performance benefits using A/M systems until you reach at least 500+ Hp.
Problem with Banks is they are "Legends in their own minds" they are masters at slick marketing, and overpriced products.
You did not list the mods on your truck, but for $400 bucks there are several proven mods that you could purchase that would be a much better use of the money IMO.
Have you installed a "Fluidampr", coolant filter, fuel cross over kit, gauges, exhaust?
