I have serious movement of my steering wheel from the tilt area.('78 Bronco). I actually must hold 'up' the steering wheel to keep it from resting in my lap! I have been told that if I remove the steering wheel and the turn signal apparatus, I will find two bolts that secure the upper part or the steering wheel to the tilt portion? And, all I most likely will need to do is tighten the two nuts?? That simple, maybe??? I can not find a repair manual (know of one?) that details my Bronco that well!
I you can find a Mitchell manual for the steering and suspension it usually has a exploded view of the steering column. These are geared toward professional shops so im not sure where to tell you to look for one.
Sorry Bob,
didn't mean to put all those >>>> in there. My bad. still learning.....
again thanks for the cat advice. can't wait for it to get here!
windy
