2003 F150 tire size change
To break it down for tires.... 265-60-17.....means 265mm wide... thats the width of the tread....now for the 60.... that means that the side wal is 60% of the width so in your case it will be 159mm tall side wall. the 17 means the diameter of the rim....
so...
275-60-17 is 275mm wide and 165mm tall side wall
265-60-17 is 265mm wide and 159mm tall side wall....
so you are losing 10mm on width and 6mm on height... not much differnce... hope this makes it simple.
so...
so...
so...
Fender
Sidewall
Wheel
Sidewall
Ground
the peppermint
12-31-2012 12:01 AM
ronjoli
05-09-2002 12:51 PM
