repalcing aft axle fuel tank
i have a 1995 f250 longbed and i have to install a new fuel tank due to its leaking, what would i need to do to replace the stock 18 gal tank with a larger bronco tank, i do have a frame hitch but the spare is in the bed. also would like to replace the filler necks with the higher flow filler necks any and all input would be greatfully accepted thanks ahead of time
you need the tank, the pump*, and the straps. You'll loose the spare tire carrier thats below your 18g tank.
*You can use the 18g tanks pump but it won't reach the bottom of the bronco tank so You'll only get 18g out of it... in case you need something to work until you get a bronco pump. It will read empty after 18 or so gallons, thats because its not long enough to sense the rest of the gas under it. Many people are confused about that and insist the pump gets it all.
Yep I'd get the upper/lower straps Tank and pump off like year Bronco donor. That way its plug and play . There may be light fab work to mount straps as the Bronco tank is narrower from front to back . (at least the on I put on 10 yrs ago was.) But its not bad. Keep us posted on how it goes.
