Diagram for Motorcraft 2150 adjustments
Old 05-07-2007, 02:16 PM
lud04X's Avatar
lud04X
lud04X is offline
Anyone have a picture or diagram of the 2150 carb and what screws adjust what. I rebuilt the carb but I have no idea what adjustments I need to make and what screw does what.
Old 05-07-2007, 03:52 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
If you didn't have the diagram, how did you rebuild the carb? A really good blowup diagram should have come with the kit. The two screws on the front of the carb underneath adjust the idle mixture. The large screw on the drivers side adjusts the curb idle. The three screws on the choke cap are for loosening the choke cap so that it can be adjusted. The small screw on the back of the choke pull-down diaphragm is for adjusting the pull-down spacing. The screw on the back passenger side is for fast idle speed. The hex screw on the neoprene choke linkage is for the fast idle index. That is every screw on a 2150.
Old 05-07-2007, 04:11 PM
lud04X's Avatar
lud04X
lud04X is offline
I should have metnioned that I have misplaced the diagram from my rebuild kit. Sorry about the confusion. Thanks for helping me out.
Old 05-08-2007, 07:55 AM
subford's Avatar
subford
subford is offline
Stockdale Dave
05-20-2009 01:18 PM
amory
01-19-2009 05:36 PM
boggerted
11-29-2007 09:22 AM
webster
05-24-2007 06:56 AM
scarl
09-14-2003 12:17 AM
Quick Reply: Diagram for Motorcraft 2150 adjustments
