How to fix front axle shaft???
I was replacing a unit bearing on my 99 SD for the second time, but the first time doing it myself.
I bought a seal for the axle shaft that is loacted on the back side of the knuckle by the u-joint, but haven't the foggiest on how to replace the seal??? It seems like it can't go over the u-joint side or the more outer side. Though this is not that big of deal since I mangled the thin steel flange that is part of the outer axle stub - when I was pulling the axle out of the knuckle.
Any ideas? The dealer quoted me $600 for the whole RF axle shaft assembly. I think I may want to do the knucke as well since the inside of it is a bit rusty even after a lot of sanding.
The brakes had been dragging slightly on the RF for a long time and contributed the knuckle getting hot enough to dry up all the grease complicating the matter.
The seal I think your talking about is at the endoff the axle tube???
to put that on the axle gets pulled out of the tube.
You just pry on the u-joint with 2 screw drivers and work it out.
If you are leaking axle fluid ,that means that your inner seals are shot or your axle is rusted and pitted where the seal rides.
The big knuckle seal needs a special tool to put on or the tool that can be made from parts at your local hardware store.
Do a search for a post on How to change your ball joints
Depending on how deep the rust pits are on the inside of the knuckle are ,you cantake a cylinder hone and clean it up.
Rich
Rich
Actually the seal I am having trouble with is F81Z3254CB, the knuckle seal as some call it.
If I did make a special tool to install that seal, would it pass over the u-joint area of the axle shaft to get to its final placement?
I will have to purchase a new outer stub shaft as I bent the flange that the knuckle seal butts up to. I am debating if I want to just put a new knuckle on too.
How does the ABS sensor come out of the knuckle on SD's with 4 wheel ABS?
I am considering buying a whole new axle assembly, since I could upgrade to the Dana 60 for a little more than a new knuckle and RF axle shaft, but I have RWABS.
Did the Excursion have the Dana 60 from 2002 and newer?
Can you post pictures of what you have so we can see exactly what is broken and what is not? It would help us help you.
As far as the ABS sensor, I don't know, I have never replaced one because the unit bearing always went out before the sensor did, and new ones come with a new sensor.
If I recall correctly, that part of the shaft that the seal goes onto and butts up against is machined steel, so you are not going to bend it. I think what you are reffering to is actually a portion of the seal. The knuckle seal is quite complex in design and has the ability to move in and out within itself. It also is not surprising that it got bent either, as it often happens on removal. Have you aquired the new seal yet?
So the metal flange that the plastic hex washer(the one with grooves facing the inside) is placed up next to is removable from the stub shaft??
I kinda tried to see if that was a separate piece, but it seemed to be part of the shaft.
I have these
F81Z3254CB Hub Seal
F81Z4A322AA Yellow O-Ring
I do not have
F81Z1S175HCA Axle Seal
I have these
F81Z3254CB Hub Seal
I do not have
Yes, that is part of the hub seal and will be all nice and new again with a new seal. Just remember to use the installer tool, or you can booger up the new one real easy! In addition to the parts you have, I would suggest you get the black o-ring that goes on the lockout, and new stud kit for the unit bearing. It saves a lot of fooling around after the fact. When you put everything back together, just remember to apply a light coating of grease to the surfaces that the seals and o-rings seat against. The hubs are vacuum actuated and will not operate properly if the assebled hub/unit bearing assembly has a leak.
I got everything you list except for the part I bent up, so I'm going to make a trip to the dealer to try and get it. Also, I'll have to create the driver for the seal.
Thank you!
I have it all in working order again - the tin piece that I was worried about was actually just part of the knuckle seal.
I drove the seal on using the old unit bearing assembly. I just set the old assembly wheel studs toward the floor, set the new seal on the old assembly, placed the axle on the top and tapped the end of the axle that goes into the diff.
